* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -15/+35 |
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -2/+4 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -4/+4 |
| | | | | Update #3220. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -14/+70 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Review changes from Chris Mayfield. | Chris Johns | 2016-05-02 | 1 | -2/+2 |
* | Corrections from Worth Burruss. Many thanks. | Chris Johns | 2016-05-02 | 1 | -4/+3 |
* | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 2016-05-02 | 1 | -0/+4 |
* | Split installation into separate files. | Chris Johns | 2016-05-02 | 1 | -1/+0 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 1 | -3/+8 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+10 |
