path: root/user/index.rst (follow)
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* user: Rework "Hardware" chapterSebastian Huber2019-01-141-2/+2
| | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section.
* user: Move "Ecosystem" into "Introduction"Sebastian Huber2019-01-141-2/+0
* user: Move "Support" to "Introduction"Sebastian Huber2019-01-141-2/+0
| | | | | New users may find it useful to get this information in the introduction.
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+12
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* user: Add RSB content as a chapterSebastian Huber2019-01-141-15/+18
| | | | Remove the separate RSB manual.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* user: Add RTEMS executable and test documentation.Chris Johns2018-11-031-2/+4
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-1/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* user: Add ARM BSPs chapterSebastian Huber2018-06-261-0/+1
| | | | | | Add NXP i.MX section as a BSP example. Update #2854.
* Adding Trace DocumentationVidushi Vashishth2018-06-181-0/+2
| | | | | | | | - Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations.
* Use '.. toctree::' and not '.. include::' in the User Manual.Chris Johns2017-11-131-1/+1
| | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232.
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-9/+30
* user: Add tool commands to the user manual.Chris Johns2017-03-151-0/+2
* Update document titles for consistencyJoel Sherrill2017-01-111-3/+3
* user: Fix header levels.Chris Johns2016-11-091-1/+1
* Fix spelling.Chris Johns2016-11-021-1/+1
* Add a Hardware section.Chris Johns2016-07-061-2/+1
* Reorganisse the User Manual to make it easier to navigate.Chris Johns2016-07-041-4/+9
* Set SPDX License Identifier in each source file.Chris Johns2016-05-201-0/+2
* User manual, devel install and windows install.Chris Johns2016-05-021-9/+4
* Initial reST documentation using Sphinx.Amar Takhar2016-05-021-0/+36
