* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | user: Add deployment section | Chris Johns | 2022-09-13 | 1 | -1/+2 |
* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 1 | -0/+1 |
| | | | | Update #3818. | ||||
* | user: update copyright and minor typo | Gedare Bloom | 2020-04-04 | 1 | -0/+1 |
* | Update top-level copyrights | Gedare Bloom | 2020-04-03 | 1 | -1/+2 |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 1 | -0/+1 |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | ||||
* | user: Add a migration chapter | Chris Johns | 2020-03-13 | 1 | -0/+2 |
| | | | | | | | This is a start with the hope we collect useful pieces to aid porting. Please add to this. Closes #3895 | ||||
* | user: Update Quick Start Guide | Chris Johns | 2020-03-13 | 1 | -1/+1 |
| | | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | ||||
* | user/index: Add myself to the list of copyrights | Vijay Kumar Banerjee | 2019-08-15 | 1 | -0/+1 |
* | user: Improve bug report section | Sebastian Huber | 2019-08-08 | 1 | -1/+2 |
| | | | | | | | | | | | The new content is based on the wiki page: https://devel.rtems.org/wiki/Developer/Bug_Reporting The goal is to remove the wiki page and direct the "New ticket" page to this user manual section. Some content of the wiki page should move to the "Contributing" sections since it is not directly related to bug reporting, e.g. managing existing bugs. | ||||
* | user: Move support sections to top level | Sebastian Huber | 2019-08-06 | 1 | -0/+1 |
| | | | | | This is a preparation step to move the bug reporting procedure from the wiki to the user manual and to add a contributing section. | ||||
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -8/+10 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 1 | -2/+2 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 1 | -2/+0 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 1 | -2/+0 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+12 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 1 | -15/+18 |
| | | | | Remove the separate RSB manual. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 1 | -2/+4 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 1 | -0/+1 |
| | | | | | | Add NXP i.MX section as a BSP example. Update #2854. | ||||
* | Adding Trace Documentation | Vidushi Vashishth | 2018-06-18 | 1 | -0/+2 |
| | | | | | | | | - Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -1/+1 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 1 | -2/+1 |
| | | | | Update #3229. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -9/+30 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 1 | -0/+2 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -3/+3 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Fix spelling. | Chris Johns | 2016-11-02 | 1 | -1/+1 |
* | Add a Hardware section. | Chris Johns | 2016-07-06 | 1 | -2/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -4/+9 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 1 | -9/+4 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+36 |
