This is a start with the hope we collect useful pieces to aid porting.
Please add to this.
Closes #3895
- Add support for release source archives
- Add building the BSP using the RSB
- Add building packages using the RSB
- Add an application
Closes #2998
The new content is based on the wiki page:
https://devel.rtems.org/wiki/Developer/Bug_Reporting
The goal is to remove the wiki page and direct the "New ticket" page to
this user manual section. Some content of the wiki page should move to
the "Contributing" sections since it is not directly related to bug
reporting, e.g. managing existing bugs.
This is a preparation step to move the bug reporting procedure from the
wiki to the user manual and to add a contributing section.
- This change makes the copyright character easier to see on editors
lacking good unicode rendering support, ie terminals.
Rename it to "Target Hardware". Remove BSPs section and reference the
BSPs chapter instead. Remove explicit list of architectures and
reference the BSPs chapter instead. Fix typos. Elaborate multilib
description in the architecture section.
New users may find it useful to get this information in the
introduction.
For everything before 2015 an OAR copyright is assumed. Later copyright
notices are based on Git commits on a best effort basis.
The copyright notices of the "RTEMS Software Engineering Handbook" and
the "RTEMS CPU Architecture Supplement" are incomplete.
Remove the separate RSB manual.
- Remove all genindex.rst files, these are generated and should not
exist in our source.
- Fix the HTML templates so the local specialisation works.
- Add a index link to the sidebar for HTML.
Note, there is no TOC entry for the index in the PDF output and I
cannot figure out how to add one.
Closes #3503
Add NXP i.MX section as a BSP example.
Update #2854.
- Updates #3454
- This commit adds Tracing Framework Chapter in the RTEMS User Manual
- It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace
generation techniques explaining trace generation using Trace Buffering and
Printk generators and sample demonstrations.
- Change all suitable '.. include::' to TOC tree.
- Remove unused and not needed sections.
- Fix the conf.py to not exclude some files.
Close #3232.
Update #3229.
