* | xilinx-zynqmp.rst: Documented SDIO driver | Stephen Clark | 2021-07-15 | 1 | -0/+14 |
| | | | | Added documentation for SDIO driver. | ||||
* | user: Update ZynqMP network configuration | Kinsey Moore | 2021-07-15 | 1 | -8/+3 |
| | | | | | Network configuration is now automatic and requires no user configuration. | ||||
* | user/bsps/imxrt: Info about ARM PLL frequency | Christian Mauderer | 2021-07-02 | 1 | -0/+20 |
| | | | | Update #4180 | ||||
* | user/bsps/imxrt: Fix typo | Christian Mauderer | 2021-07-02 | 1 | -1/+1 |
* | user/bsps: Update ZynqMP for hardware BSPs | Kinsey Moore | 2021-07-01 | 1 | -8/+49 |
| | | | | | | Update the ZynqMP documentation for the new hardware BSP variants including information about booting, boot image generation, and networking. | ||||
* | user/bsps: add aarch64 xilinx-versal | Gedare Bloom | 2021-06-22 | 2 | -0/+40 |
* | user: add bsps/aarch64/a72.rst | Gedare Bloom | 2021-06-08 | 2 | -0/+36 |
* | user: fix typo in aarch64/a53.rst | Gedare Bloom | 2021-06-08 | 1 | -1/+1 |
* | bsps/imxrt: Remove superfluous options from dtc | Christian Mauderer | 2021-05-28 | 1 | -1/+1 |
| | | | | | | | | | | | The -@ option adds symbols that are used when applying an overlay. RTEMS doesn't support overlays or re-parsing of device trees. So the symbols only increase the size of the binary. The same is true for the padding. It would be useful if the device tree is changed during run time which is not supported in RTEMS. Update #4180 | ||||
* | user/bsps/arm/beagle: Update i2c initialization instructions | G S Niteesh Babu | 2021-04-22 | 1 | -13/+28 |
| | | | | | The new i2c driver in the beagle BSP uses FDT based initialization. This updates the documentation of the BSP about the same. | ||||
* | user/bsps: Add STM32H7 SDMMC driver | Christian Mauderer | 2021-04-01 | 1 | -0/+26 |
| | | | | Update #4372 | ||||
* | User/BSPs/Beagle: Add JTAG debugger section | Christian Mauderer | 2021-03-30 | 1 | -2/+65 |
* | user/bsps: Mention fixed console baud rate for zynq | Jan Sommer | 2021-03-16 | 1 | -0/+12 |
* | user: Update ZynqMP QEMU BSP name | Kinsey Moore | 2021-03-05 | 1 | -5/+6 |
| | | | | | | The ZynqMP QEMU BSPs have had _qemu added to their names to better identify them as QEMU BSPs similar to other BSPs which are meant to run exclusively on QEMU and not hardware. | ||||
* | STM32H7 doc update | Robin Mueller | 2021-02-18 | 1 | -1/+17 |
* | user: Update aarch64/xilinx-zynqmp Qemu command | Kinsey Moore | 2021-01-14 | 1 | -1/+1 |
| | | | | | | The Xilinx ZynqMP BSP has been updated to use the second UART in the memory map as the primary UART since this is how both the hardware and Qemu use them. | ||||
* | user/bsp/imxrt: Information for custom FDT | Christian Mauderer | 2020-12-14 | 1 | -8/+38 |
| | | | | Update #4180 | ||||
* | user: Add aarch64/xilinx-zynqmp | Kinsey Moore | 2020-12-11 | 2 | -0/+36 |
* | user: Add A53 Qemu run instructions | Kinsey Moore | 2020-12-11 | 1 | -0/+8 |
* | aarch64: Update interrupt details | Kinsey Moore | 2020-12-11 | 1 | -2/+3 |
* | user/bsps: Fix list in bsps-arm | Christian Mauderer | 2020-11-20 | 1 | -2/+2 |
| | | | | Seems that some filenames haven't been added correctly. | ||||
* | user/bsps: Add imxrt | Christian Mauderer | 2020-11-20 | 2 | -0/+174 |
| | | | | Update #4180 | ||||
* | user: Add arm/stm32h7 | Sebastian Huber | 2020-10-27 | 3 | -0/+66 |
| | | | | Close #3910. | ||||
* | user: Rename files to match the chapter index | Sebastian Huber | 2020-10-27 | 2 | -0/+0 |
* | user/beagle: Add debug hardware mod | Chris Johns | 2020-10-19 | 1 | -0/+61 |
* | Add AArch64 documentation | Kinsey Moore | 2020-10-05 | 2 | -1/+27 |
* | i386: tweak grammar and style | Gedare Bloom | 2020-09-21 | 1 | -7/+4 |
* | pc386 BSP: add runtime options for debugging and move few lines around for ↵ | Karel Gardas | 2020-09-21 | 1 | -5/+27 |
| | | | | better context. | ||||
* | pc386 BSP: add a note about default baud rate for console over UART/COM. | Karel Gardas | 2020-09-21 | 1 | -0/+4 |
* | user/pc386 BSP: add documentation. | Karel Gardas | 2020-09-09 | 1 | -1/+395 |
| | | | | | The content is compiled from TBR pc386 wiki page, BSP's README files and from the actual BSP code. | ||||
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | Reflect removal of the epiphany target | Sebastian Huber | 2020-07-05 | 2 | -12/+0 |
| | | | | Update #3941. | ||||
* | user: Document arm/realview-pbx-a9 BSP | Sebastian Huber | 2020-07-02 | 1 | -2/+14 |
* | user/imx: Add i.MX6UL/ULL. | Christian Mauderer | 2020-04-15 | 1 | -3/+44 |
| | | | | Update #3869 | ||||
* | doc: Moving M68K BSP Content to User Manual (#3905) | Mritunjay | 2020-04-03 | 1 | -2/+188 |
| | | | | Fixed trailing spaces. | ||||
* | gdbarmsim: Remove all references to this deleted BSP family | Joel Sherrill | 2020-03-20 | 2 | -9/+0 |
| | | | | Updates #3611. | ||||
* | user/raspberrypi: Fix typo | G S Niteesh Babu | 2020-03-19 | 1 | -1/+1 |
| | | | | enable-uart should be enable_uart in config.txt | ||||
* | user: Add anchors to some BSPs. | Chris Johns | 2020-03-13 | 2 | -0/+15 |
* | doc/raspberrypi: Added instructions for raspberrypi | G S Niteesh | 2020-02-15 | 1 | -1/+110 |
| | | | | Added instructions to run examples on raspberrypi. | ||||
* | bsp/xen: Add information on Xen/ARM BSP | Jeff Kubascik | 2019-12-20 | 2 | -0/+80 |
| | | | | Add a README for the new xen bsp. | ||||
* | user: Mention xilinx-zynqmp BSP | Sebastian Huber | 2019-12-19 | 2 | -0/+9 |
| | | | | Close #3682. | ||||
* | user: Add frdme310arty BSP varient | Pragnesh Patel | 2019-11-29 | 1 | -0/+8 |
| | | | | | | Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com> Update #3785. | ||||
* | bsps/beagle: update i2c section | Vijay Kumar Banerjee | 2019-09-26 | 1 | -3/+3 |
* | user/exe: Add link reference in device-tree | Vijay Kumar Banerjee | 2019-08-11 | 1 | -1/+1 |
* | user/bsps: Fix typo in beagle | Vijay Kumar Banerjee | 2019-08-08 | 1 | -2/+2 |
* | user/exe: Add Device Tree section | Vijay Kumar Banerjee | 2019-08-07 | 1 | -19/+2 |
* | user/bsps : Fix formatting and typo in arm/beagle | Vijay Kumar Banerjee | 2019-07-27 | 1 | -18/+37 |
* | user/bsps : Add documentation for Beagle | Vijay Kumar Banerjee | 2019-07-20 | 1 | -2/+89 |
* | user: Split the ARM BSPs source into separate files. | Chris Johns | 2019-07-12 | 20 | -382/+458 |
* | user: Document boot image generation | Sebastian Huber | 2019-05-27 | 1 | -1/+12 |
| | | | | Update #3727. |
