brains GmbH.
This patch adds the documentation for building and running RTEMS on the Kendryte K210 RISC-V SoC.
The generic riscv introducion was re-arranged to list the multilib variants then the specific
hardware targets. In addition a couple of errors were fixed for the generic QEMU commands.
V2 corrected a typo, expanded K210 Console UART parameters, and addded a hyperlink to renode.io install
instructions.
V3 clarified the multilib variant description, clarified the multilib variant reference platform, and
corrected capitalization on SiFive.
V4 improves the instructions for running the K210 BSP on the Renode.io simulator.
V5 cleaned up the text to be no more than 80 characters per line.
V6 applied word wrap to paragraphs and replaced hard coded RTEMS major versions with macros.
Closes #4876
RISC-V SoC. The generic riscv introducion was re-arranged to list the multilib variants
then the specific hardware targets. In addition a couple of errors were fixed for the
to renode.io install instructions.
Closes #4876
Updates #4779.
Closes #4779
Closes #4775
The BSP is capable of initialising the hardware being the first software
that takes control on hardware reset (after the bootrom). For instance,
using on QEMU's virt platforms, RTEMS runs as a bios without BBL.
Similarily, RTEMS can also be run on harware/FPGA and loaded using
GDB; the bootrom (or a GDB script) should just set the a0/a1 registers
with the boot HART ID and DTB address respectively.
Update the riscv documentation for the Microchip PolarFire SoC
BSP variant including information about SMP test procedure
for the Microchip PolarFire Icicle Kit.
Updates #4695
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Update #3785.
Update #3678.
Update #3464.
Update #3433.
Update #3464.
