* | rtems-docs: add example booting aarch64 image on Xilinx ZCU102 | Alan Cudmore | 2022-03-25 | 1 | -0/+167 |
| | | | | | | This patch is for the rtems-docs repo. I added details on the procedure I used to boot RTEMS images on the Xilinx ZCU102 board. I applied this patch, and generated the HTML docs, and everything looks ok to me. | ||||
* | user/bsps/aarch64: Minor formatting fix | Stephen Clark | 2021-07-15 | 2 | -6/+10 |
| | | | | | Fixed formatting error in user/bsps/aarch64/a53.rst and user/bsps/aarch64/xilinx-zynqmp.rst. | ||||
* | xilinx-zynqmp.rst: Documented SDIO driver | Stephen Clark | 2021-07-15 | 1 | -0/+14 |
| | | | | Added documentation for SDIO driver. | ||||
* | user: Update ZynqMP network configuration | Kinsey Moore | 2021-07-15 | 1 | -8/+3 |
| | | | | | Network configuration is now automatic and requires no user configuration. | ||||
* | user/bsps: Update ZynqMP for hardware BSPs | Kinsey Moore | 2021-07-01 | 1 | -8/+49 |
| | | | | | | Update the ZynqMP documentation for the new hardware BSP variants including information about booting, boot image generation, and networking. | ||||
* | user/bsps: add aarch64 xilinx-versal | Gedare Bloom | 2021-06-22 | 1 | -0/+39 |
* | user: add bsps/aarch64/a72.rst | Gedare Bloom | 2021-06-08 | 1 | -0/+35 |
* | user: fix typo in aarch64/a53.rst | Gedare Bloom | 2021-06-08 | 1 | -1/+1 |
* | user: Update ZynqMP QEMU BSP name | Kinsey Moore | 2021-03-05 | 1 | -5/+6 |
| | | | | | | The ZynqMP QEMU BSPs have had _qemu added to their names to better identify them as QEMU BSPs similar to other BSPs which are meant to run exclusively on QEMU and not hardware. | ||||
* | user: Update aarch64/xilinx-zynqmp Qemu command | Kinsey Moore | 2021-01-14 | 1 | -1/+1 |
| | | | | | | The Xilinx ZynqMP BSP has been updated to use the second UART in the memory map as the primary UART since this is how both the hardware and Qemu use them. | ||||
* | user: Add aarch64/xilinx-zynqmp | Kinsey Moore | 2020-12-11 | 1 | -0/+35 |
* | user: Add A53 Qemu run instructions | Kinsey Moore | 2020-12-11 | 1 | -0/+8 |
* | aarch64: Update interrupt details | Kinsey Moore | 2020-12-11 | 1 | -2/+3 |
* | Add AArch64 documentation | Kinsey Moore | 2020-10-05 | 1 | -0/+26 |
