Add a list of known working hardware and commentary about bitstream
loading for specific hardware.
Updates #4695
This patch is for the rtems-docs repo. I added details on the procedure I
used to boot RTEMS images on the Xilinx ZCU102 board. I applied this patch,
and generated the HTML docs, and everything looks ok to me.
Fixed formatting error in user/bsps/aarch64/a53.rst
and user/bsps/aarch64/xilinx-zynqmp.rst.
Added documentation for SDIO driver.
Network configuration is now automatic and requires no user
configuration.
Update the ZynqMP documentation for the new hardware BSP variants
including information about booting, boot image generation, and
networking.
The ZynqMP QEMU BSPs have had _qemu added to their names to better
identify them as QEMU BSPs similar to other BSPs which are meant to run
exclusively on QEMU and not hardware.
The Xilinx ZynqMP BSP has been updated to use the second UART in the
memory map as the primary UART since this is how both the hardware and
Qemu use them.
