There are still sys.path hacks in the conf.py files. They cannot
be removed because the instance of python running the sphinx-build
command does not see our top level path hacks. I looked at using
PYTHONPATH but I could not figure out how to set a process environ
var for a waf build instance.
This avoids conflicts with standard packages such as PIL (Python Imaging
Library).
For everything before 2015 an OAR copyright is assumed. Later copyright
notices are based on Git commits on a best effort basis.
The copyright notices of the "RTEMS Software Engineering Handbook" and
the "RTEMS CPU Architecture Supplement" are incomplete.
In the RTEMS POSIX 1003.1 Compliance Guide it says:
The following methods and variables in <sys/times.h> are supported:
- times()
- utimes()
But according to the official POSIX Specifications
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html,
<sys/times.h> only declares times(), and utimes() is decleared by
<sys/time.h> (notice that it's time, not times) according to
http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html
and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html.
This patch fixes this error.
This work was part of GCI 2018.
- Remove all genindex.rst files, these are generated and should not
exist in our source.
- Fix the HTML templates so the local specialisation works.
- Add a index link to the sidebar for HTML.
Note, there is no TOC entry for the index in the PDF output and I
cannot figure out how to add one.
Closes #3503
This update adds the following:
C11 Programming Language Standard
FACE Technical Standard Edition 3.0 (four profiles)
Software Communication Architecture Specification 2.2.2 (one profile)
Software Communication Architecture Specification 4.1 (three profiles)
Update #3229.
Update #3220.
- Move the copyright to the top of the generated file.
- Add a glossary and references section.
Closes #3177.
This is a replacement of the POSIX 1003.1 Compliance Guide. It
will be generated from a .csv file.
Updates #3177.
