path: root/posix-compliance (follow)
* Update Compliance Tracking CSV file to fix minor bugsJoel Sherrill2021-06-042-873/+874
* posix-compliance: Update to include POSIX 1003.1-2017 (Issue 7).Joel Sherrill2021-05-174-1379/+1395
* posix-compliance/posix_rst.py: Use proper names of standards in headingsJoel Sherrill2021-05-171-18/+18
* posix-compliance: Use constant name for API spreadsheet.Joel Sherrill2021-04-073-26/+49
| | | | | | | README-cvs.txt will need to be updated each time the spreadsheet is updated. The spreadsheet is managed and maintained externally and has a version in the name. We do not want that in the repository because a diff of the CSV should always be much smaller than a "delete old/add new" patch.
* posix-compliance: Update tracking spreadsheet to v12Joel Sherrill2021-04-075-1364/+1398
| | | | | | | | | | The new version of the API tracking spreadsheet includes FACE Technical Standard, Edition 3.1 as well as a few additions to what RTEMS supports. The generation script and discussion of standards was updated to reflect the inclusion of a new Edition of the FACE Technical Standard. Closes #4380.
* Add missing <math.h> methods implemented as macros on compiler builtins.Joel Sherrill2020-09-142-1357/+1357
| | | | | | | These methods have long been provided and this change is needed on the 5.x branch and master. Closes #4075.
* posix-compliance: Add some missing methodsJoel Sherrill2020-03-212-220/+220
* posix-compliance: Add ndbm.h supportJoel Sherrill2019-11-062-893/+893
* waf: Add support for extra and excluded sources.Chris Johns2019-02-281-1/+2
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-2/+4
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* waf: Fix python3 issues.Chris Johns2019-02-281-1/+1
| | | | - Found after updating to FreeBSD-12.0 which defaults to Python3.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* waf: Remove as many sys path hacks as we can.Chris Johns2019-02-131-11/+7
| | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
* build: Prepend project common pathSebastian Huber2019-02-082-2/+2
| | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library).
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-7/+4
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-114-4/+4
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-112-3/+2
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* posix-compliance: Change utimes() from sys/times.h to sys/time.hMarçal Comajoan Cara2018-12-092-8/+8
| | | | | | | | | | | | | | | | | | | In the RTEMS POSIX 1003.1 Compliance Guide it says: The following methods and variables in <sys/times.h> are supported: - times() - utimes() But according to the official POSIX Specifications http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html, <sys/times.h> only declares times(), and utimes() is decleared by <sys/time.h> (notice that it's time, not times) according to http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html. This patch fixes this error. This work was part of GCI 2018.
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-212-5/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Update the POSIX Compliance Tracking Spreadsheet. Add standards.Joel Sherrill2018-03-096-1208/+1434
| | | | | | | | | This update adds the following: C11 Programming Language Standard FACE Technical Standard Edition 3.0 (four profiles) Software Communication Architecture Specification 2.2.2 (one profile) Software Communication Architecture Specification 4.1 (three profiles)
* posix-compliance: Add description of standardsJoel Sherrill2018-03-093-5/+84
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Change RTEMS version to 5Sebastian Huber2017-11-091-2/+2
| | | | Update #3220.
* posix-compliance: Latex does not like an empty glossary.Chris Johns2017-10-131-0/+5
* posix-compliance: Reference the generated content via the include file.Chris Johns2017-10-135-7/+24
| | | | | - Move the copyright to the top of the generated file. - Add a glossary and references section.
* posix-compliance: Fix the pdflatex file created by Sphinx.Chris Johns2017-10-121-1/+1
* build: Remove the grouping in posix-compliance.Chris Johns2017-10-121-1/+0
* posix-compliance: Add automatic generation of the ReST file from CSV data.Chris Johns2017-10-123-1/+291
| | | | Closes #3177.
* New version of POSIX Compliance GuideJoel Sherrill2017-10-128-0/+1412
This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177.
