* | coding-naming: Convert TBD to Rest format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+85 | |
* | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+641 | |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | |||||
* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+353 | |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | |||||
* | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2018-12-17 | 2 | -2/+154 | |
* | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 2018-12-17 | 1 | -1/+1 | |
* | eng/license-requirements.rst: Add a TBD for BSD info | Joel Sherrill | 2018-12-17 | 1 | -0/+1 | |
* | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2018-12-17 | 2 | -321/+651 | |
* | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+33 | |
* | coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -4/+384 | |
* | coding-gen-patch:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+27 | |
* | eng/coding-80cols: Convert wiki page to Rest | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+146 | |
| | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line to Rest, and TBDs into comments. This work was part of GCI 2018. | |||||
* | eng/appendix-a: convert to a table | Marçal Comajoan Cara | 2018-12-17 | 1 | -50/+106 | |
| | | | | | | | Convert text to a table, TBDs into comments and add missing formatting. This work was part of GCI 2018. | |||||
* | eng/test-suites.rst: Update to reflect current reality | Joel Sherrill | 2018-12-17 | 1 | -6/+24 | |
* | test-suites:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+32 | |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 30 | -0/+649 | |
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. |
