* | glossary: Add terms | Sebastian Huber | 2023-12-19 | 3 | -9/+25 |
* | eng: Add formal verification chapter | Andrew Butterfield | 2023-11-09 | 11 | -0/+3268 |
* | eng: Allow target attribute in build script items | Sebastian Huber | 2023-09-18 | 1 | -0/+5 |
* | eng: add Apache License 2.0 restriction | Karel Gardas | 2023-07-28 | 1 | -1/+25 |
* | eng: Add guidelines for validation tests | Sebastian Huber | 2023-06-26 | 1 | -0/+78 |
| | | | | Update #3717. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 19 | -33/+33 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | eng: Add register block specification types | Sebastian Huber | 2023-05-19 | 1 | -0/+337 |
| | | | | | | | | | | | | | | | A register block may be used to specify the interface of devices which contain registers associated with an integer address. Register blocks consist of register block members specified by the ``definition`` attribute. Register block members are either instances of registers specified by the ``registers`` attribute or instances of other register blocks specified by links with the "register-block-include" link role. Registers consists of bit fields. The register block members are placed into the address space of the device relative to the base address of the register block. Register member offests and the register block size are specified in units of the address space granule. Update #3715. | ||||
* | eng: Add unspecified header file item type | Sebastian Huber | 2023-05-09 | 1 | -0/+24 |
* | eng: Make design group identifiers optional | Sebastian Huber | 2023-05-05 | 1 | -3/+19 |
* | eng: Add an item type for not defined defines | Sebastian Huber | 2023-05-05 | 1 | -0/+3 |
| | | | | | | | This helps to deduce that a missing define in the software design is intended. Update #3715. | ||||
* | eng: Remove ambiguous interface types | Sebastian Huber | 2023-05-05 | 1 | -6/+0 |
| | | | | | | Use an item proxy instead. Update #3715. | ||||
* | eng: Add proxy item type | Sebastian Huber | 2023-05-05 | 1 | -0/+29 |
* | eng: Add design target item type | Sebastian Huber | 2023-05-04 | 1 | -0/+25 |
* | eng: Remove obsolete type listing | Sebastian Huber | 2023-05-04 | 1 | -2/+0 |
* | eng: Update application configuration how-to | Sebastian Huber | 2023-05-04 | 2 | -28/+28 |
| | | | | | | | Change paths to be in line with the actual specification. Fix group membership link role. Update #3715. | ||||
* | eng: Add optional floating-point number type | Sebastian Huber | 2023-05-04 | 1 | -0/+11 |
* | eng: Use type refinement for validation method | Sebastian Huber | 2023-05-04 | 1 | -2/+5 |
* | eng: Add conditional build dependencies | Sebastian Huber | 2023-05-04 | 1 | -0/+18 |
* | eng: Generalize external references | Sebastian Huber | 2023-05-04 | 1 | -63/+115 |
| | | | | | | | Use a common subtype for external references of interfaces and requirements. Add specializations for document and file references. Update #3715. | ||||
* | eng: Rework performance meansurement items | Sebastian Huber | 2023-05-04 | 2 | -54/+56 |
| | | | | | | | Use links to specify runtime performance limits in target-specific items. Clarify wording. Update #3715. | ||||
* | eng/vc-users.rst: Fix markup for subjectprefix | Kinsey Moore | 2023-03-23 | 1 | -0/+1 |
| | | | | | This was missing a line and causing the code block to not appear in the rendered document. | ||||
* | eng: Remove test-suite-name attribute | Sebastian Huber | 2023-02-16 | 1 | -4/+0 |
* | eng: Add ObjectsItem details | Kinsey Moore | 2023-02-09 | 2 | -2/+35 |
| | | | | This adds a section on adding ObjectsItems. | ||||
* | eng: Use a recommendation for requirement texts | Sebastian Huber | 2023-01-23 | 1 | -63/+63 |
* | eng: Add reason to test program state | Sebastian Huber | 2023-01-23 | 1 | -8/+19 |
* | eng: Improve build option default values | Sebastian Huber | 2023-01-23 | 1 | -37/+25 |
| | | | | | Merge "default" and "default-by-variant" attributes. Use an enabled-by expression to select the default value. | ||||
* | eng: Add more flags to build group item | Sebastian Huber | 2023-01-23 | 1 | -0/+8 |
* | eng/vc-users.rst: Add commit message guidance | Joel Sherrill | 2022-12-14 | 1 | -6/+77 |
| | | | | Closes #4274. | ||||
* | eng, user: update bsp_list to bsplist | Gedare Bloom | 2022-11-11 | 1 | -1/+1 |
* | eng, user: update bsp_defaults to bspdefaults | Gedare Bloom | 2022-11-11 | 1 | -1/+1 |
* | eng: Fix typos | Matt Joyce | 2022-11-08 | 1 | -4/+4 |
* | eng: show how to set local default subject-prefix | Gedare Bloom | 2022-11-03 | 1 | -0/+5 |
* | eng: Add memory benachmark type refinement | Sebastian Huber | 2022-10-04 | 1 | -4/+10 |
* | eng: Use type refinement for validation method | Sebastian Huber | 2022-10-04 | 1 | -18/+22 |
* | eng: Remove appl config group member link role | Sebastian Huber | 2022-10-04 | 1 | -9/+0 |
* | eng: Refine unspecified interfaces | Sebastian Huber | 2022-10-04 | 1 | -3/+24 |
* | eng: Add function implementation link role | Sebastian Huber | 2022-10-04 | 1 | -1/+14 |
* | eng: Unify interface function and macro | Sebastian Huber | 2022-10-04 | 1 | -107/+66 |
| | | | | | | This allows the documentation of parameter and return types for macros. Update #3715. | ||||
* | eng: Remove interface container item type | Sebastian Huber | 2022-10-04 | 1 | -19/+1 |
* | eng: Document new build item attributes | Sebastian Huber | 2022-09-08 | 1 | -0/+20 |
| | | | | Close #4670. | ||||
* | eng/req/howto.rst: Fix ./spec2dmodules.py to ./spec2modules.py typo | Joel Sherrill | 2022-08-11 | 1 | -1/+1 |
* | eng/coding-conventions.rst: Fix duplicate periods | Joel Sherrill | 2022-06-15 | 1 | -1/+1 |
* | eng/tester.rst: Reference User Manual for rtems-test | Joel Sherrill | 2022-03-24 | 1 | -4/+9 |
| | | | | This was just a TBD section of no value before. | ||||
* | eng: Add rtems-central.git post branch procedures | Sebastian Huber | 2022-01-28 | 1 | -8/+18 |
* | eng: Fix indentation | Sebastian Huber | 2022-01-28 | 1 | -16/+16 |
* | eng: Update version number handling | Sebastian Huber | 2022-01-28 | 1 | -7/+7 |
* | eng: Add script usage to how-to | Sebastian Huber | 2022-01-24 | 1 | -1/+102 |
* | eng: Document get-string-command-line action | Sebastian Huber | 2022-01-11 | 1 | -4/+4 |
| | | | | Update #4548. | ||||
* | eng: Add runtime performance kinds | Sebastian Huber | 2022-01-11 | 1 | -0/+4 |
* | eng: Document get-string-command-line action | Sebastian Huber | 2022-01-11 | 1 | -0/+6 |
| | | | | Close #4548. |
