* | eng: Remove text attribute from acfg options | Sebastian Huber | 2021-04-30 | 1 | -6/+0 |
| | | | | Update #3715. | ||||
* | eng: Add test suite name | Sebastian Huber | 2021-04-29 | 1 | -0/+4 |
* | eng: Remove scope from constraints | Sebastian Huber | 2021-04-29 | 1 | -4/+0 |
| | | | | | | Use links instead of this special purpose attributes. Update #3715. | ||||
* | eng: Add unit test link role | Sebastian Huber | 2021-04-29 | 1 | -2/+23 |
* | eng: Remove embedded constraints | Sebastian Huber | 2021-04-29 | 1 | -44/+1 |
* | eng: Allow multiple interface references | Sebastian Huber | 2021-04-27 | 1 | -3/+18 |
* | eng: Add example to action requirements how-to | Sebastian Huber | 2021-03-19 | 2 | -4/+406 |
* | eng: Document expressions in action requirements | Sebastian Huber | 2021-03-19 | 1 | -11/+198 |
* | eng: Add build/appl config clauses to how-to | Sebastian Huber | 2021-03-19 | 1 | -0/+122 |
* | eng: Update EARS syntax | Sebastian Huber | 2021-03-19 | 2 | -41/+64 |
| | | | | | | | | | The document used the EARS syntax from 2009 which slightly changed in 2016, see "Listens Learned (8 Lessons Learned Applying EARS)". The optional pre-conditions moved to the state-driven pattern. This refined syntax fits better to the action requirements. Update #3715. | ||||
* | eng/vc-users: Set up patch message with repo name | Meh Mbeh Ida Delphine | 2021-03-16 | 1 | -0/+8 |
| | | | | | | | Added instructions on how to set up a patch message with a repo name. Author: Meh Mbeh Ida Delphine <idadelm@gmail.com> Date: Tue Mar 16 19:11:23 2021 +0100 | ||||
* | eng: Clarify how-to for action requirements | Sebastian Huber | 2021-03-11 | 1 | -9/+9 |
| | | | | | | Bring how-to in line with current action requirements. Update #3715. | ||||
* | eng: Clarify how-to for action requirements | Sebastian Huber | 2021-03-11 | 1 | -1/+41 |
* | eng: Clarify how-to for action requirements | Sebastian Huber | 2021-03-08 | 1 | -2/+3 |
* | eng: Add how-to for action requirements | Sebastian Huber | 2021-03-08 | 1 | -1/+178 |
* | eng: Fix typo | Sebastian Huber | 2021-03-02 | 1 | -1/+1 |
* | eng: Update test case item | Sebastian Huber | 2021-02-08 | 1 | -26/+31 |
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 1 | -3/+7 |
* | eng: Add design group requirement item type | Sebastian Huber | 2021-01-15 | 1 | -0/+24 |
* | eng: Add performance specification items | Sebastian Huber | 2020-11-27 | 1 | -113/+502 |
| | | | | | | Add items to specify runtime performance requirements. Update #3715. | ||||
* | eng: Rework and clarify Doxygen Guidelines | Sebastian Huber | 2020-11-20 | 2 | -63/+149 |
* | eng: Fix typo | Sebastian Huber | 2020-11-19 | 1 | -102/+103 |
* | eng: Simplify "Load" environment reporting | Sebastian Huber | 2020-11-13 | 1 | -14/+7 |
| | | | | | | | Report all runtime measurement environments with a name only and encode the worker count of the "Load" environment in the name. Update #3199. | ||||
* | eng: Rename ValidCache environment in FullCache | Sebastian Huber | 2020-11-13 | 1 | -7/+8 |
| | | | | | | | This name better reflects the execution envirnoment in which the cache is fully loaded with valid data unrelated to the body request handler. Update #3199. | ||||
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 1 | -5/+4 |
* | eng: Move code formatting rules into one section | Sebastian Huber | 2020-11-11 | 4 | -181/+197 |
| | | | | | Clarify the 80 character limit. Change the line continuation indent level. | ||||
* | eng: Clarify "Coding Conventions" introduction | Sebastian Huber | 2020-11-11 | 1 | -5/+5 |
* | eng: Clarify "Source Documentation" section | Sebastian Huber | 2020-11-11 | 2 | -10/+19 |
* | eng: Add header file conventions | Sebastian Huber | 2020-11-11 | 3 | -0/+41 |
* | eng: Remove "Generating a Tools Patch" | Sebastian Huber | 2020-11-11 | 2 | -36/+0 |
| | | | | | This section is probably some left over stuff from CVS times. The topic is already covered by the "Software Development (Git Users)" section. | ||||
* | eng: Add function attributes | Sebastian Huber | 2020-11-09 | 1 | -0/+7 |
* | eng: Replace spec2doc.py with spec2modules.py | Sebastian Huber | 2020-10-24 | 1 | -7/+7 |
* | eng: Add placement link role | Sebastian Huber | 2020-10-11 | 1 | -0/+12 |
* | eng: Move index-entries to all interfaces | Sebastian Huber | 2020-10-11 | 1 | -6/+5 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 1 | -4/+9 |
* | eng: Remove explicit figure class | Sebastian Huber | 2020-10-09 | 1 | -2/+0 |
| | | | | This makes the legend left justified. | ||||
* | eng: Add proper figure titles | Sebastian Huber | 2020-10-08 | 1 | -0/+4 |
| | | | | The first paragraph of a figure directive block is the figure title. | ||||
* | eng: Clarify stlib build attribute | Sebastian Huber | 2020-10-01 | 1 | -13/+32 |
| | | | | Update #4107. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-09-28 | 1 | -1/+1 |
* | eng/test-framework.rst -- Fix typo | Frank Kühndel | 2020-09-18 | 1 | -3/+3 |
* | eng: Remove double blank line | Sebastian Huber | 2020-09-18 | 1 | -1/+0 |
* | eng: Update release process | Sebastian Huber | 2020-09-18 | 1 | -2/+6 |
* | eng: Add BSP build system chapter | Sebastian Huber | 2020-09-13 | 2 | -0/+490 |
| | | | | Update #3818. | ||||
* | eng: Update the python template, add a shell template | Chris Johns | 2020-09-01 | 1 | -4/+59 |
* | eng: Add automatically generated warning | Sebastian Huber | 2020-08-19 | 1 | -0/+7 |
* | eng: Unify test attribute keys | Sebastian Huber | 2020-08-19 | 1 | -19/+19 |
* | eng: Add test header to test case | Sebastian Huber | 2020-08-19 | 1 | -77/+82 |
* | eng: Remove test name attribute | Sebastian Huber | 2020-08-19 | 1 | -28/+0 |
| | | | | | | Derive the test name from the item UID. Update #3715. | ||||
* | eng: Add test case attributes | Sebastian Huber | 2020-08-19 | 1 | -0/+18 |
* | eng: Add Doxyfile update to release process | Sebastian Huber | 2020-08-10 | 1 | -0/+2 |
