* | Use a complete sentence for acronym definitions | Sebastian Huber | 2020-06-04 | 1 | -10/+10 | |
* | eng: Add interface specification how-to | Sebastian Huber | 2020-06-01 | 2 | -0/+89 | |
| | | | | Update #3715. | |||||
* | eng: Update requirements tooling section | Sebastian Huber | 2020-05-29 | 1 | -11/+22 | |
* | eng: Add generated documentation of spec items | Sebastian Huber | 2020-05-29 | 6 | -414/+4255 | |
| | | | | | | | | | The documentation of the specification items is generated by an RTEMS qualification tool from a specification of specification items. Move non-generated content to "req-for-req.rst". Update #3715. | |||||
* | eng: Split up requirements engineering chapter | Sebastian Huber | 2020-05-29 | 9 | -1283/+1309 | |
| | | | | | | | This allows to more easily generate the specification item section with a script using specification items. Update #3715. | |||||
* | eng: Update requirements engineering chapter | Sebastian Huber | 2020-05-05 | 1 | -304/+409 | |
| | | | | | | | | | Update requirements engineering chapter due to the removal of Doorstop as the requirements management tool. Update the application configuration related specification items. Update #3715. | |||||
* | Rework RTEMS licensing discussions. | Joel Sherrill | 2020-05-01 | 2 | -14/+96 | |
| | | | | | | | This now captures historical rationale along with cross-linking code templates with license guidelines. Closes #3962. | |||||
* | eng: Adjust config.h include | Sebastian Huber | 2020-04-15 | 1 | -1/+1 | |
| | | | | Use variant used by most source files. | |||||
* | Add a release procedure section. | Chris Johns | 2020-04-04 | 2 | -3/+271 | |
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 2 | -0/+80 | |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | |||||
* | eng: Add glossary terms | Sebastian Huber | 2020-04-01 | 2 | -3/+92 | |
| | | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | |||||
* | eng: Add Python development guidelines | Sebastian Huber | 2020-03-19 | 2 | -0/+164 | |
* | eng: Add glossary | Sebastian Huber | 2020-03-02 | 2 | -0/+62 | |
| | | | | Update #3853. | |||||
* | eng: Fix typo | Sebastian Huber | 2020-02-25 | 1 | -1/+1 | |
* | eng: Rework file template section | Sebastian Huber | 2020-02-24 | 1 | -30/+240 | |
| | | | | Update #3053. | |||||
* | eng: Grammar fix | Sebastian Huber | 2020-02-10 | 1 | -1/+1 | |
| | | | | Update #3199. | |||||
* | eng: Mention test framework buffer configuration | Sebastian Huber | 2020-02-10 | 1 | -2/+7 | |
* | eng: Document test framework formatted output | Sebastian Huber | 2020-02-10 | 1 | -7/+23 | |
* | Revert "common: Add URLs to manuals" | Sebastian Huber | 2020-02-04 | 1 | -2/+3 | |
| | | | | | This reverts commit 1fdd3cf83d154af66ad0edf5094d93075063c7e0 and some follow up changes. | |||||
* | eng: Add Software Requirements Engineering chapter | Sebastian Huber | 2020-01-07 | 2 | -0/+1178 | |
* | eng: Rework stakeholder chapter | Sebastian Huber | 2020-01-07 | 3 | -18/+20 | |
* | eng: Rework preface and add mission statement | Sebastian Huber | 2020-01-07 | 4 | -23/+83 | |
| | | | | | | | | Add mission statement based on the wiki page: https://devel.rtems.org/wiki/Mission_Statement Do format changes and some rewording. | |||||
* | Move contributing content from eng to user | Sebastian Huber | 2019-10-30 | 2 | -152/+0 | |
* | eng: Update issue tracking section | Sebastian Huber | 2019-10-30 | 1 | -13/+8 | |
* | eng: Add bibliography | Sebastian Huber | 2019-07-24 | 2 | -0/+7 | |
* | eng: Rework Doxygen guidelines | Sebastian Huber | 2019-04-05 | 1 | -441/+235 | |
| | | | | Update #3704. | |||||
* | bsp-howto: Move BSP Doxygen recommendations | Sebastian Huber | 2019-04-04 | 2 | -718/+0 | |
* | eng: Add software test framework chapter | Sebastian Huber | 2019-03-27 | 2 | -0/+2255 | |
* | eng: Change title to RTEMS Software Engineering | Sebastian Huber | 2019-03-27 | 2 | -5/+5 | |
| | | | | Use a shorter title so that the PDF page header fits into one line. | |||||
* | eng: Reformat | Sebastian Huber | 2019-03-13 | 1 | -14/+14 | |
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -1/+3 | |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 | |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 | |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | |||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 | |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+5 | |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 28 | -28/+28 | |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 28 | -35/+31 | |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 | |
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 7 | -18/+18 | |
* | eng: Unicode char (U+200B) | Sebastian Huber | 2018-12-20 | 1 | -3/+3 | |
* | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+244 | |
* | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 2018-12-17 | 1 | -352/+360 | |
| | | | | This work was part of GCI 2018. | |||||
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 | |
* | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 2018-12-17 | 1 | -315/+362 | |
* | Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) | zehata | 2018-12-17 | 1 | -1/+417 | |
* | coding-naming: Convert TBD to Rest format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+85 | |
* | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+641 | |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | |||||
* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+353 | |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | |||||
* | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2018-12-17 | 2 | -2/+154 | |
* | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 2018-12-17 | 1 | -1/+1 | |
