* | rtems-docs: remove Eclipse Manual | Ray Garza | 2021-07-06 | 1 | -14/+0 |
| | | | | | Due to RTEMS 6 no longer using the Make build system and instead using Waf (Eclipse does not offer Waf support), this guide is being removed. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 1 | -1/+1 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | Add Eclipse user manual for RTEMS. | Chris Johns | 2016-05-20 | 1 | -0/+13 |
