path: root/cpu-supplement (follow)
* Reflect removal of the epiphany targetSebastian Huber2020-07-051-85/+4
| | | | Update #3941.
* cpu-supplement: Update ARM multilibsSebastian Huber2019-05-151-14/+10
| | | | Update #3747.
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-5/+7
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* waf: Remove as many sys path hacks as we can.Chris Johns2019-02-131-11/+7
| | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
* Add copyright noticesSebastian Huber2019-02-084-0/+5
* build: Prepend project common pathSebastian Huber2019-02-082-2/+2
| | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library).
* cpu-supplement: Fix file nameSebastian Huber2019-02-072-1/+1
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+7
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-1121-21/+21
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-1118-18/+0
* Use standard format for copyright linesSebastian Huber2019-01-1119-33/+19
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* cpu-supplement: Update ARM multilibsSebastian Huber2019-01-071-7/+18
* sparc_v8_stacks_regwin.rst: Add middle initail for Peter MagnussonJoel Sherrill2018-12-201-2/+2
| | | | | | Peter requested this after reviewing the converted content. He noted that it was a nit but he had consistently used his middle initial in all academic settings and wanted to be consistent.
* cpu-supplement/sparc.rst: Merge Annul Slot Explanation (GCI 2018)zehata2018-11-201-0/+45
| | | | | This content originated as an email response from Jiri Gaisler to Joel Sherrill in response to a question.
* cpu-supplement/sparc_v8_stacks_regwin.rst: Add credit boxJoel Sherrill2018-11-201-0/+8
* cpu-supplement/sparc_v8_stacks_regwin.rst: Complete FormattingMarçal Comajoan Cara2018-11-201-49/+48
| | | | This work was part of GCI 2018.
* cpu-supplement/sparc_v8_stacks_regwin.rst: Simplify section titleJoel Sherrill2018-11-191-2/+2
* Improve SPARC Calling Overview Webpage conversionMarçal Comajoan Cara2018-11-191-209/+75
| | | | | | | | | Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567.
* cpu-supplement/sparc_v8_stacks_regwin.rst: Basic formatting with TBDsJoel Sherrill2018-11-191-51/+271
| | | | Leaving notes for follow up as a GCI 2018 task.
* Initial addition of SPARC V8 Stack/Register Windowing from Peter MagnussonJoel Sherrill2018-11-192-0/+413
| | | | | | | | | This content was originally at https://www.sics.se/~psm/sparcstack.html and is currently only available via the Wayback Machine. Peter kindly gave permission to include it with the RTEMS Documentation. This initial commit is a cut and paste with minimal edits. Edits are needed to ensure proper formatting and the figures need to be made to look correct in the Rest formatted output.
* Remove m32c architecture portSebastian Huber2018-11-091-9/+1
| | | | Update #3599.
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-0/+2
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* cpu-supplement/sparc.rst: Revert work in progress accidentally committedJoel Sherrill2018-08-201-593/+0
* cpu-supplement/sparc.rst: Fix meJoel Sherrill2018-08-201-0/+593
* cpu-supplement: Remove empty indexSebastian Huber2018-08-202-6/+0
| | | | | | | | Due to the hierarchical structure an index is not absolutely necessary and an empty index is not helpful. The document sources contain no index directives. Close #3499.
* cpu-supplement: Remove empty command/vars chapterSebastian Huber2018-08-202-9/+0
| | | | Close #3498.
* Fix SPARC_SWTRAP_IRQDIS typoJoel Sherrill2018-08-091-1/+1
| | | | close #3493.
* cpu-supplement: Add RISC-V chapterSebastian Huber2018-08-022-0/+80
| | | | Update #3433.
* cpu-supplement: Update interrupt stack paragraphSebastian Huber2018-07-191-10/+14
| | | | Close #3459.
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Shorten the name of the BSP and Device Driver Development GuideJoel Sherrill2017-10-122-11/+5
| | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141.
* Mention i.MX 7 SMP supportSebastian Huber2017-09-271-2/+7
| | | | Update #3090.
* cpu-supplement: Use literal instead of emphasisSebastian Huber2017-08-251-10/+11
| | | | Update #3082.
* cpu-supplement: Fix PowerPC TOC limitationSebastian Huber2017-08-241-2/+3
| | | | Update #3082.
* cpu-supplement/powerpc: RewriteSebastian Huber2017-08-231-475/+38
| | | | | | | Remove obsolete and duplicated information. Reference the ABI specifications. Add 64-bit caveats. Update #3082.
* Update copyright notices.Chris Johns2017-08-111-4/+7
* cpu-supplement: Update TLS support statusSebastian Huber2017-06-121-1/+1
| | | | Close #2468.
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-6/+5
* c-user: Add support for references via bibtexSebastian Huber2017-01-184-1/+10
| | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871.
* Update document titles for consistencyJoel Sherrill2017-01-112-5/+5
* Remove references to SPARC/SIS BSP. Also clean up old ERC32 references.Joel Sherrill2017-01-111-22/+5
| | | | updates #2810.
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-1/+1
* cpu-supplement: Document PowerPC SPRG0-2 usageSebastian Huber2016-11-101-0/+11
* cpu-supplement: Fix the project label.Chris Johns2016-11-091-0/+2
* cpu-supplement: Fix header levels.Chris Johns2016-11-0921-23/+24
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-0322-0/+4329
