* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 18 | -18/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 19 | -33/+19 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | cpu-supplement: Update ARM multilibs | Sebastian Huber | 2019-01-07 | 1 | -7/+18 |
* | sparc_v8_stacks_regwin.rst: Add middle initail for Peter Magnusson | Joel Sherrill | 2018-12-20 | 1 | -2/+2 |
| | | | | | | Peter requested this after reviewing the converted content. He noted that it was a nit but he had consistently used his middle initial in all academic settings and wanted to be consistent. | ||||
* | cpu-supplement/sparc.rst: Merge Annul Slot Explanation (GCI 2018) | zehata | 2018-11-20 | 1 | -0/+45 |
| | | | | | This content originated as an email response from Jiri Gaisler to Joel Sherrill in response to a question. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Add credit box | Joel Sherrill | 2018-11-20 | 1 | -0/+8 |
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Complete Formatting | Marçal Comajoan Cara | 2018-11-20 | 1 | -49/+48 |
| | | | | This work was part of GCI 2018. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Simplify section title | Joel Sherrill | 2018-11-19 | 1 | -2/+2 |
* | Improve SPARC Calling Overview Webpage conversion | Marçal Comajoan Cara | 2018-11-19 | 1 | -209/+75 |
| | | | | | | | | | Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Basic formatting with TBDs | Joel Sherrill | 2018-11-19 | 1 | -51/+271 |
| | | | | Leaving notes for follow up as a GCI 2018 task. | ||||
* | Initial addition of SPARC V8 Stack/Register Windowing from Peter Magnusson | Joel Sherrill | 2018-11-19 | 2 | -0/+413 |
| | | | | | | | | | This content was originally at https://www.sics.se/~psm/sparcstack.html and is currently only available via the Wayback Machine. Peter kindly gave permission to include it with the RTEMS Documentation. This initial commit is a cut and paste with minimal edits. Edits are needed to ensure proper formatting and the figures need to be made to look correct in the Rest formatted output. | ||||
* | Remove m32c architecture port | Sebastian Huber | 2018-11-09 | 1 | -9/+1 |
| | | | | Update #3599. | ||||
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -0/+2 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | cpu-supplement/sparc.rst: Revert work in progress accidentally committed | Joel Sherrill | 2018-08-20 | 1 | -593/+0 |
* | cpu-supplement/sparc.rst: Fix me | Joel Sherrill | 2018-08-20 | 1 | -0/+593 |
* | cpu-supplement: Remove empty index | Sebastian Huber | 2018-08-20 | 2 | -6/+0 |
| | | | | | | | | Due to the hierarchical structure an index is not absolutely necessary and an empty index is not helpful. The document sources contain no index directives. Close #3499. | ||||
* | cpu-supplement: Remove empty command/vars chapter | Sebastian Huber | 2018-08-20 | 2 | -9/+0 |
| | | | | Close #3498. | ||||
* | Fix SPARC_SWTRAP_IRQDIS typo | Joel Sherrill | 2018-08-09 | 1 | -1/+1 |
| | | | | close #3493. | ||||
* | cpu-supplement: Add RISC-V chapter | Sebastian Huber | 2018-08-02 | 2 | -0/+80 |
| | | | | Update #3433. | ||||
* | cpu-supplement: Update interrupt stack paragraph | Sebastian Huber | 2018-07-19 | 1 | -10/+14 |
| | | | | Close #3459. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 2 | -11/+5 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | Mention i.MX 7 SMP support | Sebastian Huber | 2017-09-27 | 1 | -2/+7 |
| | | | | Update #3090. | ||||
* | cpu-supplement: Use literal instead of emphasis | Sebastian Huber | 2017-08-25 | 1 | -10/+11 |
| | | | | Update #3082. | ||||
* | cpu-supplement: Fix PowerPC TOC limitation | Sebastian Huber | 2017-08-24 | 1 | -2/+3 |
* | cpu-supplement/powerpc: Rewrite | Sebastian Huber | 2017-08-23 | 1 | -475/+38 |
| | | | | | | | Remove obsolete and duplicated information. Reference the ABI specifications. Add 64-bit caveats. Update #3082. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -4/+7 |
* | cpu-supplement: Update TLS support status | Sebastian Huber | 2017-06-12 | 1 | -1/+1 |
| | | | | Close #2468. | ||||
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -6/+5 |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 4 | -1/+10 |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | ||||
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -5/+5 |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 1 | -22/+5 |
| | | | | updates #2810. | ||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
* | cpu-supplement: Document PowerPC SPRG0-2 usage | Sebastian Huber | 2016-11-10 | 1 | -0/+11 |
* | cpu-supplement: Fix the project label. | Chris Johns | 2016-11-09 | 1 | -0/+2 |
* | cpu-supplement: Fix header levels. | Chris Johns | 2016-11-09 | 21 | -23/+24 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 22 | -0/+4329 |
