path: root/common/sphinx_rtd_theme_rtems/static/css/fonts/lato-bold-italic.woff (follow)
* sphinx: Use the pip installed sphinx-rtd-themeChris Johns2024-02-211-0/+0
| | | | | | | | | | | | - Remove the RTEMS version of the theme - Use conf.py to specify our style sheet - Depend on the jQuery contrib package for including jQuery - Detect the theme is installed Closes #4994
* Update sphinx_rtd_theme to https://github.com/readthedocs/sphinx_rtd_theme/Amar Takhar2020-02-261-0/+0
68a19ca / 0.4.3.dev0. I have been using this one for a while without issues. This should fix the search issues. closes #3880
