path: root/common/sphinx_rtd_theme_rtems/layout.html (follow)
* sphinx: Use the pip installed sphinx-rtd-themeChris Johns2024-02-211-244/+0
| | | | | | | | | | | | - Remove the RTEMS version of the theme - Use conf.py to specify our style sheet - Depend on the jQuery contrib package for including jQuery - Detect the theme is installed Closes #4994
* sphinx/style: Fix building with the latest sphinxChris Johns2023-12-201-1/+5
| | | | | | Tested on sphinx 7.2, 6.1.3 AND 5.3.0 Closes #4980
* layout.html: Revert patch forcing Spinx to >= 6.0Joel Sherrill2023-07-251-2/+0
| | | | | | | | | | | | | | | | | | | Unfortunately, updating past Sphinx 5.x results in unordered bullet lists not formatting correctly as show in a screen capture attached to #4928. Revert this patch until the issue is resolved and output is reviewed for other potential issues. From: Utkarsh Verma <utkarsh@bitbanged.com> Date: Wed, 14 Jun 2023 05:36:26 +0000 Subject: [PATCH] eng: Fix builds for newer Sphinx versions (>=7) The current Sphinx theme depends on the `style` parameter which got deprecated in v5.1 and finally got removed in v7. Now, the `styles` key should be preferred which is a list of stylesheets. This commit implements this change. Updates #4915. Updates #4928.
* eng: Fix builds for newer Sphinx versions (>=7)Utkarsh Verma2023-06-141-0/+2
| | | | | | | | | The current Sphinx theme depends on the `style` parameter which got deprecated in v5.1 and finally got removed in v7. Now, the `styles` key should be preferred which is a list of stylesheets. This commit implements this change. Closes #4915
* Update sphinx_rtd_theme to https://github.com/readthedocs/sphinx_rtd_theme/Amar Takhar2020-02-261-75/+119
| | | | | | | | | 68a19ca / 0.4.3.dev0. I have been using this one for a while without issues. This should fix the search issues. closes #3880
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-3/+0
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add my-style.css support and add RTEMS to that CSS.Chris Johns2016-05-021-0/+3
* Add support for singlehtml (inlined) HTML file, plus some other fixes.Amar Takhar2016-05-021-0/+196
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this.
