* | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 2016-05-02 | 1 | -49/+9 |
| | | | | | | | | | * This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | ||||
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 1 | -8/+7 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 1 | -0/+2 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+252 |
