* | sphinx: Use the pip installed sphinx-rtd-theme | Chris Johns | 2024-02-21 | 1 | -3/+10 |
| | | | | | | | | | | | | - Remove the RTEMS version of the theme - Use conf.py to specify our style sheet - Depend on the jQuery contrib package for including jQuery - Detect the theme is installed Closes #4994 | ||||
* | building: Add support for an RTEMS version number | Chris Johns | 2022-08-03 | 1 | -8/+4 |
| | | | | | | - Support using a version number for RTEMS documentation Updates #4695 | ||||
* | common: use bibtex_bibfiles for newer bibtex | Gedare Bloom | 2021-02-18 | 1 | -0/+2 |
| | | | | Closes #4229. | ||||
* | common: Enable numfig role | Sebastian Huber | 2020-09-13 | 1 | -0/+3 |
* | common: fix title page | Gedare Bloom | 2020-04-04 | 1 | -0/+1 |
| | | | | | Sphinx changed the default behavior of maketitle. Provide our own rtemsmaketitle command and use it instead. | ||||
* | waf: Get the version numbers from the version file. | Chris Johns | 2020-03-13 | 1 | -3/+12 |
* | common: Show page references after internal links | Sebastian Huber | 2019-08-14 | 1 | -2/+1 |
| | | | | | | | The custom RTEMS extension produced quite verbose references like "Chapter 3 - Section 7 - Bla blub". This may distract the reading flow. Use a standard Sphinx option to show page references instead, e.g. "Bla blub (page 11)". This has some value for printed out documents. | ||||
* | Remove minted from the PDF builds. | Chris Johns | 2019-02-13 | 1 | -1/+1 |
| | | | | | | This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | ||||
* | Fix building with Sphinx 1.8 and later. | Chris Johns | 2019-02-06 | 1 | -3/+5 |
| | | | | | | | | - Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | ||||
* | Change first copyright year to 1988 | Sebastian Huber | 2019-01-18 | 1 | -1/+1 |
| | | | | The OAR copyright goes back to 1988. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 1 | -24/+1 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2018-08-21 | 1 | -1/+0 |
| | | | | | I removed the '_' splitting of long labels from the index when testing and this puts it back. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -2/+4 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | common: Remove obsolete latex_use_parts | Sebastian Huber | 2017-08-25 | 1 | -4/+0 |
| | | | | | | | | This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | ||||
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | conf: Update the copyright year. | Chris Johns | 2017-03-21 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -3/+3 |
* | Move extensions to common conf.py | Sebastian Huber | 2017-02-22 | 1 | -1/+2 |
* | Do not show page references after internal links | Sebastian Huber | 2017-02-01 | 1 | -1/+1 |
* | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 2017-01-11 | 1 | -1/+7 |
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 1 | -1/+0 |
* | conf: Make the build date use a nicer day format. | Chris Johns | 2016-11-03 | 1 | -1/+16 |
* | Add a copyright to the PDF front page. | Chris Johns | 2016-11-02 | 1 | -2/+3 |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 |
* | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Fix PDF layout. | Chris Johns | 2016-05-02 | 1 | -2/+2 |
* | Add my-style.css support and add RTEMS to that CSS. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 2016-05-02 | 1 | -49/+9 |
| | | | | | | | | | * This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | ||||
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 1 | -8/+7 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 1 | -0/+2 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+252 |
