* | c-user: Split up timer manager | Sebastian Huber | 2020-09-02 | 1 | -643/+0 |
| | | | | | | | This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -1/+1 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -10/+20 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -24/+24 |
* | c-user: Update timer manager | Sebastian Huber | 2017-01-30 | 1 | -8/+16 |
| | | | | Update #2554. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -311/+304 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -4/+4 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+634 |
