* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 14 | -330/+414 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | c-user: CONFIGURE_BSP_PREREQUISITE_DRIVERS | Sebastian Huber | 2021-04-29 | 1 | -2/+2 |
| | | | | Replace copy and paste with a proper description. | ||||
* | c-user: Add missing "the" | Sebastian Huber | 2021-04-29 | 1 | -11/+10 |
* | c-user: Clarify constraints | Sebastian Huber | 2021-03-08 | 1 | -2/+8 |
* | c-user: Add labels to the manager chapters | Sebastian Huber | 2021-02-10 | 1 | -1/+1 |
| | | | | Update #3993. | ||||
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 14 | -42/+98 |
* | c-user: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE | Sebastian Huber | 2020-11-25 | 1 | -1/+68 |
| | | | | | | | Document new configuration option CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE. Close #4181. | ||||
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 14 | -70/+56 |
* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 14 | -0/+330 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 14 | -56/+126 |
* | c-user: Fix use of getchark() and rtems_putc() | Sebastian Huber | 2020-09-28 | 1 | -4/+4 |
* | c-user: CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE | Sebastian Huber | 2020-09-17 | 1 | -0/+32 |
| | | | | | | Document this application configuration option. Update #3959. | ||||
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 1 | -0/+44 |
| | | | | | | Document this application configuration option. Close #4074. | ||||
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 14 | -0/+98 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 14 | -98/+136 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM | Sebastian Huber | 2020-08-07 | 1 | -2/+2 |
| | | | | Improve formatting. | ||||
* | c-user: Unify references in appl config chapter | Sebastian Huber | 2020-07-23 | 4 | -62/+49 |
| | | | | | This is a prepration step to allow the generation of the application configuration options in Doxygen markup. | ||||
* | c-user: Fix CONFIGURE_MAXIMUM_PROCESSORS minimum | Sebastian Huber | 2020-07-07 | 1 | -1/+1 |
* | c-user: Fix appl config option references | Sebastian Huber | 2020-07-06 | 2 | -2/+2 |
* | c-user: Sort appl config options by name | Sebastian Huber | 2020-07-06 | 3 | -72/+72 |
* | c-user: Use * for list items | Sebastian Huber | 2020-06-17 | 4 | -51/+51 |
* | c-user: Fix RTEMS_SCHEDULER_EDF_SMP() | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3815. | ||||
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 1 | -44/+0 |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | ||||
* | c-user: Move CONFIGURE_MAXIMUM_PRIORITY | Sebastian Huber | 2020-04-02 | 2 | -58/+58 |
| | | | | | | Move this option to the scheduler configuration options. Update #3836. | ||||
* | c-user: Clarify config options use | Sebastian Huber | 2020-04-02 | 3 | -5/+34 |
* | c-user: Document all configuration options | Sebastian Huber | 2020-04-01 | 7 | -0/+666 |
| | | | | Close #2806. | ||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 14 | -748/+1203 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Avoid self references | Sebastian Huber | 2020-03-30 | 1 | -3/+3 |
| | | | | Update #3900. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-30 | 1 | -23/+35 |
* | c-user: Fix typo in file name | Sebastian Huber | 2020-03-30 | 1 | -0/+0 |
* | c-user: Document new event record config options | Sebastian Huber | 2020-03-24 | 1 | -1/+64 |
| | | | | Update #3904. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-24 | 10 | -567/+539 |
| | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Close #3900. | ||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 14 | -40/+37 |
* | c-user: Add reference to proxies | Sebastian Huber | 2020-03-17 | 1 | -3/+2 |
* | c-user: Fix format | Sebastian Huber | 2020-03-17 | 2 | -36/+36 |
* | c-user: Add configuration option index entry | Sebastian Huber | 2020-03-17 | 1 | -0/+2 |
* | c-user: Fix sorting in filesystem configuration | Sebastian Huber | 2020-03-17 | 1 | -2/+2 |
* | c-user: Add missing configuration option notes | Sebastian Huber | 2020-03-17 | 2 | -1/+49 |
* | c-user: Sort configuration options alphabetically | Sebastian Huber | 2020-03-17 | 3 | -77/+77 |
* | c-user: Obsolete CONFIGURE_MAXIMUM_DEVICES | Sebastian Huber | 2020-03-13 | 2 | -30/+10 |
| | | | | Close #3898. | ||||
* | c-user: Fix typos | Sebastian Huber | 2020-03-13 | 1 | -4/+4 |
* | c-user: Reorder configuration option groups | Sebastian Huber | 2020-03-13 | 1 | -4/+4 |
| | | | | | | | Sort the configuration option groups according to the likelihood a user will define options of a group. Update #3836. | ||||
* | c-user: Clarify message buffer configuration | Sebastian Huber | 2020-03-13 | 3 | -94/+73 |
| | | | | | | | | | The help macro CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE() is not a configuration option. Move it into the documentatation of the CONFIGURE_MESSAGE_BUFFER_MEMORY configuration option. Move this option to the general system configuration group. Update #3836. | ||||
* | c-user: Add copyright information | Sebastian Huber | 2020-03-13 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | Add copyright information according to commit in RTEMS main repository: commit e53aae2676c42cda521328504f82d26c33827021 Author: Gedare Bloom <gedare@rtems.org> Date: Mon Mar 26 16:42:38 2012 -0400 confdefs: Add declaration for unlimited objects. Adds to confdefs a way to specify rtems_resource_unlimited for classic and posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED. Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for extending the set of objects at runtime. Updates the unlimited sample to demonstrate how to use the new macros. Also adds new documentation in the C User's Manual regarding configuring with unlimited objects. | ||||
* | c-user: Move "Obsolete Configuration Options" | Sebastian Huber | 2020-03-12 | 2 | -221/+225 |
* | c-user: Move "Ada Configuration" | Sebastian Huber | 2020-03-12 | 2 | -12/+16 |
* | c-user: Move "Event Recording Configuration" | Sebastian Huber | 2020-03-12 | 2 | -58/+62 |
* | c-user: Move "PCI Library Configuration" | Sebastian Huber | 2020-03-12 | 2 | -52/+56 |
* | c-user: Move "Multiprocessing Configuration" | Sebastian Huber | 2020-03-12 | 2 | -181/+185 |
* | c-user: Move "Device Driver Configuration" | Sebastian Huber | 2020-03-12 | 2 | -504/+508 |
| | | | | Update #3836. |
