* | c-user: Fix CONFIGURE_MAXIMUM_PROCESSORS minimum | Sebastian Huber | 2020-07-07 | 1 | -1/+1 |
* | c-user: Fix appl config option references | Sebastian Huber | 2020-07-06 | 2 | -2/+2 |
* | c-user: Sort appl config options by name | Sebastian Huber | 2020-07-06 | 3 | -72/+72 |
* | c-user: Use * for list items | Sebastian Huber | 2020-06-17 | 4 | -51/+51 |
* | c-user: Fix RTEMS_SCHEDULER_EDF_SMP() | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3815. | ||||
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 1 | -44/+0 |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | ||||
* | c-user: Move CONFIGURE_MAXIMUM_PRIORITY | Sebastian Huber | 2020-04-02 | 2 | -58/+58 |
| | | | | | | Move this option to the scheduler configuration options. Update #3836. | ||||
* | c-user: Clarify config options use | Sebastian Huber | 2020-04-02 | 3 | -5/+34 |
* | c-user: Document all configuration options | Sebastian Huber | 2020-04-01 | 7 | -0/+666 |
| | | | | Close #2806. | ||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 14 | -748/+1203 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Avoid self references | Sebastian Huber | 2020-03-30 | 1 | -3/+3 |
| | | | | Update #3900. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-30 | 1 | -23/+35 |
* | c-user: Fix typo in file name | Sebastian Huber | 2020-03-30 | 1 | -0/+0 |
* | c-user: Document new event record config options | Sebastian Huber | 2020-03-24 | 1 | -1/+64 |
| | | | | Update #3904. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-24 | 10 | -567/+539 |
| | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Close #3900. | ||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 14 | -40/+37 |
* | c-user: Add reference to proxies | Sebastian Huber | 2020-03-17 | 1 | -3/+2 |
* | c-user: Fix format | Sebastian Huber | 2020-03-17 | 2 | -36/+36 |
* | c-user: Add configuration option index entry | Sebastian Huber | 2020-03-17 | 1 | -0/+2 |
* | c-user: Fix sorting in filesystem configuration | Sebastian Huber | 2020-03-17 | 1 | -2/+2 |
* | c-user: Add missing configuration option notes | Sebastian Huber | 2020-03-17 | 2 | -1/+49 |
* | c-user: Sort configuration options alphabetically | Sebastian Huber | 2020-03-17 | 3 | -77/+77 |
* | c-user: Obsolete CONFIGURE_MAXIMUM_DEVICES | Sebastian Huber | 2020-03-13 | 2 | -30/+10 |
| | | | | Close #3898. | ||||
* | c-user: Fix typos | Sebastian Huber | 2020-03-13 | 1 | -4/+4 |
* | c-user: Reorder configuration option groups | Sebastian Huber | 2020-03-13 | 1 | -4/+4 |
| | | | | | | | Sort the configuration option groups according to the likelihood a user will define options of a group. Update #3836. | ||||
* | c-user: Clarify message buffer configuration | Sebastian Huber | 2020-03-13 | 3 | -94/+73 |
| | | | | | | | | | The help macro CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE() is not a configuration option. Move it into the documentatation of the CONFIGURE_MESSAGE_BUFFER_MEMORY configuration option. Move this option to the general system configuration group. Update #3836. | ||||
* | c-user: Add copyright information | Sebastian Huber | 2020-03-13 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | Add copyright information according to commit in RTEMS main repository: commit e53aae2676c42cda521328504f82d26c33827021 Author: Gedare Bloom <gedare@rtems.org> Date: Mon Mar 26 16:42:38 2012 -0400 confdefs: Add declaration for unlimited objects. Adds to confdefs a way to specify rtems_resource_unlimited for classic and posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED. Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for extending the set of objects at runtime. Updates the unlimited sample to demonstrate how to use the new macros. Also adds new documentation in the C User's Manual regarding configuring with unlimited objects. | ||||
* | c-user: Move "Obsolete Configuration Options" | Sebastian Huber | 2020-03-12 | 2 | -221/+225 |
* | c-user: Move "Ada Configuration" | Sebastian Huber | 2020-03-12 | 2 | -12/+16 |
* | c-user: Move "Event Recording Configuration" | Sebastian Huber | 2020-03-12 | 2 | -58/+62 |
* | c-user: Move "PCI Library Configuration" | Sebastian Huber | 2020-03-12 | 2 | -52/+56 |
* | c-user: Move "Multiprocessing Configuration" | Sebastian Huber | 2020-03-12 | 2 | -181/+185 |
* | c-user: Move "Device Driver Configuration" | Sebastian Huber | 2020-03-12 | 2 | -504/+508 |
* | c-user: Move "Clustered Scheduler Configuration" | Sebastian Huber | 2020-03-12 | 2 | -216/+220 |
* | c-user: Move "General Scheduler Configuration" | Sebastian Huber | 2020-03-12 | 2 | -386/+390 |
* | c-user: Move "Idle Task Configuration" | Sebastian Huber | 2020-03-12 | 2 | -93/+97 |
* | c-user: Move "BSP Related Configuration Options" | Sebastian Huber | 2020-03-12 | 2 | -244/+248 |
* | c-user: Move "Block Device Cache Configuration" | Sebastian Huber | 2020-03-12 | 2 | -335/+339 |
* | c-user: Move "Filesystem Configuration" | Sebastian Huber | 2020-03-12 | 2 | -544/+548 |
* | c-user: Move "Message Queue Buffer Configuration" | Sebastian Huber | 2020-03-12 | 2 | -90/+94 |
* | c-user: Move "Task Stack Allocator Configuration" | Sebastian Huber | 2020-03-12 | 2 | -110/+114 |
* | c-user: Move "POSIX Initialization Thread Configuration" | Sebastian Huber | 2020-03-12 | 2 | -102/+106 |
* | c-user: Move "POSIX API Configuration" | Sebastian Huber | 2020-03-12 | 2 | -249/+253 |
* | c-user: Move "Classic API Initialization Task Configuration" | Sebastian Huber | 2020-03-12 | 2 | -231/+235 |
* | c-user: Move "Classic API Configuration" | Sebastian Huber | 2020-03-12 | 2 | -288/+292 |
* | c-user: Move "General System Configuration" | Sebastian Huber | 2020-03-12 | 2 | -636/+640 |
* | c-user: Split up configuring_a_system.rst | Sebastian Huber | 2020-03-11 | 2 | -0/+4977 |
Introduce an index file for this chapter. This helps to generate some sections from the specification in the future. Start with moving "Introduction" up to "Unlimited Objects" to a new file. Update #3836. |
