path: root/c-user/cache/introduction.rst (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* c-user: Add "Cache Manager" chapterSebastian Huber2021-09-131-0/+101
The Cache Manager directives are available via <rtems.h>. Document most of them in the Classic API Guide. Not documented are the following directive since the API is not yet stable: * rtems_cache_coherent_allocate() * rtems_cache_coherent_free() * rtems_cache_coherent_add_area() Not documented are the following directive since the directives are not implemented on maintained platforms: * rtems_cache_freeze_data() * rtems_cache_freeze_instruction() * rtems_cache_unfreeze_data() * rtems_cache_unfreeze_instruction() Close #4513.
