* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -5/+5 |
* | Update Console Driver chapter | Sebastian Huber | 2016-12-23 | 1 | -382/+346 |
| | | | | | Close #2785. Close #2838. | ||||
* | Strip down BSP Introduction | Sebastian Huber | 2016-12-21 | 1 | -49/+13 |
| | | | | Update #2852. | ||||
* | Add warnings to basic BSP chapters | Sebastian Huber | 2016-12-21 | 5 | -0/+20 |
* | Move Shared Memory Support Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
| | | | | | This chapter is very specific. Move it to a less prominent chapter position. | ||||
* | Move Ada95 Interrupt Support chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -1/+6 |
| | | | | | | Move Timer Driver chapter. Update #2847. | ||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 3 | -2/+16 |
| | | | | Close #2849. | ||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -218/+0 |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -191/+0 |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Analog Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -166/+0 |
| | | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850. | ||||
* | Document I2C framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 |
| | | | | Update #2845. | ||||
* | Document SPI framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 |
| | | | | Update #2776. | ||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | Rework Clock Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -100/+137 |
| | | | | Update #2737. | ||||
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | bsp-howto: Fix header levels. | Chris Johns | 2016-11-09 | 20 | -23/+22 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 23 | -0/+4656 |
