* | README: Add a note about image tools | Chris Johns | 2022-10-13 | 1 | -0/+15 |
* | building: Add support for an RTEMS version number | Chris Johns | 2022-08-03 | 1 | -0/+31 |
| | | | | | | - Support using a version number for RTEMS documentation Updates #4695 | ||||
* | README: Added centOS 8 instructions | Stephen Clark | 2021-07-20 | 1 | -0/+11 |
| | | | | Added some instructions for setting up CentOS 8. | ||||
* | README: Minor clarifications and fixes | Stephen Clark | 2021-07-20 | 1 | -24/+25 |
| | | | | | | Fixed some minor typographical errors. Updated a dead link. Reworded some sentences for clarity. | ||||
* | user, README: Add Python script host set up information | Chris Johns | 2020-08-12 | 1 | -6/+12 |
| | | | | | | | | | - Add Python3 and venv to the README - Add a section on how to set up a host if the python command is not available. Update #4037 | ||||
* | RTEMS Docs: Add steps for sphinxcontrib-bibtex | Vaibhav Gupta | 2020-04-03 | 1 | -0/+1 |
| | | | | | | | | Add step to install sphinxcontrib-bibtex together with the steps mentioned for ArcLinux, to install sphinx and dependencies. Signed-off-by: Vaibhav Gupta <vaibhavgupta40@gmail.com> | ||||
* | Add virtualenv to the README.txt as the preferred host support. | Chris Johns | 2020-04-03 | 1 | -1/+21 |
* | README.txt: Add info on CentOS 7 Software Collections for Python 3 | Joel Sherrill | 2019-11-06 | 1 | -2/+24 |
* | Remove back-slash in 'pacman' command in 'PDF' section under Arch Linux ↵ | Vaibhav Gupta | 2019-08-15 | 1 | -1/+1 |
| | | | | (installation of Sphinx). | ||||
* | Add commands and output to the README. | Chris Johns | 2019-02-28 | 1 | -4/+24 |
* | Add a cheetsheet link to the README.txt | Chris Johns | 2019-02-28 | 1 | -0/+4 |
* | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 2019-02-28 | 1 | -4/+40 |
| | | | | | Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | ||||
* | README.txt: Fix typos | Joel Sherrill | 2019-02-13 | 1 | -2/+2 |
* | README.txt: Fix grammar errors (GCI 2018) | Aneendya | 2018-11-16 | 1 | -3/+3 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 1 | -2/+41 |
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 1 | -1/+16 |
* | README: fix typos | Gedare Bloom | 2017-07-26 | 1 | -8/+8 |
* | Fixes typos in README.txt | Tanu Hari Dixit | 2017-05-31 | 1 | -2/+2 |
| | | | | 2 typos fixed | ||||
* | README.txt: Add info after installing on CentOS 7 | Joel Sherrill | 2017-04-25 | 1 | -5/+22 |
* | Add Windows build details. | Chris Johns | 2017-03-27 | 1 | -0/+23 |
| | | | | Actually include the quoting fix for Windows. | ||||
* | Render math via JavaScript in HTML output | Sebastian Huber | 2017-02-20 | 1 | -3/+2 |
* | Update README due to use of math extension | Sebastian Huber | 2017-02-02 | 1 | -2/+3 |
* | Mention sphinxcontrib-bibtex in README | Sebastian Huber | 2017-01-20 | 1 | -1/+3 |
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 1 | -2/+7 |
| | | | | build PDF. | ||||
* | README: Add coding of spaces and no trailing white space. | Chris Johns | 2016-11-09 | 1 | -7/+9 |
* | README: Fix the header levels. | Chris Johns | 2016-11-09 | 1 | -6/+8 |
* | README.txt: Add notes on Centos 6 and 7 | Joel Sherrill | 2016-11-08 | 1 | -5/+46 |
* | Add openSUSE installation hints | Sebastian Huber | 2016-11-07 | 1 | -1/+14 |
* | README: Add packages for building on Arch. | Christian Mauderer | 2016-11-07 | 1 | -0/+12 |
* | README: Update with more host specific details. | Chris Johns | 2016-11-06 | 1 | -18/+40 |
* | waf: note about tex noise when running configure. | Chris Johns | 2016-11-04 | 1 | -0/+3 |
* | README: Add host set up for CentOS for singlehtml. | Chris Johns | 2016-11-04 | 1 | -0/+5 |
* | waf: Check for texlive packages and report an error is not found. | Chris Johns | 2016-11-04 | 1 | -3/+92 |
* | README: Add host set up and update the build commands. | Chris Johns | 2016-11-03 | 1 | -5/+38 |
* | Update the top level README.txt. | Chris Johns | 2016-11-02 | 1 | -9/+19 |
* | Add some notes on writing documentation. | Chris Johns | 2016-11-01 | 1 | -0/+130 |
