* | coverpage: Rename the static images directory to match bootstrap. | Chris Johns | 2017-01-12 | 3 | -2/+2 | |
* | coverpage: Fix the catalogue table id. | Chris Johns | 2017-01-12 | 1 | -1/+2 | |
* | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 2017-01-12 | 14 | -20/+51 | |
| | | | | Add each doc's conf.py as a dependence to catalogue.xml. | |||||
* | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 2017-01-11 | 1 | -1/+7 | |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 22 | -60/+60 | |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 3 | -24/+7 | |
| | | | | updates #2810. | |||||
* | html: Embed the catalogue XML in JS. | Chris Johns | 2017-01-11 | 4 | -43/+81 | |
| | | | | | The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | |||||
* | html: Add support for an HTML cover page for releases. | Chris Johns | 2017-01-11 | 11 | -1/+279 | |
* | waf: Add a title to the XML Catalogue. | Chris Johns | 2017-01-10 | 2 | -9/+17 | |
* | waf: Improved XML Catalogue generator. | Chris Johns | 2017-01-10 | 2 | -49/+47 | |
* | waf: Create an XML Catalogue. | Chris Johns | 2017-01-09 | 2 | -0/+84 | |
* | waf: Update to waf-1.9.7 | Chris Johns | 2017-01-05 | 1 | -8/+8 | |
* | Update Console Driver chapter | Sebastian Huber | 2016-12-23 | 1 | -382/+346 | |
| | | | | | Close #2785. Close #2838. | |||||
* | Strip down BSP Introduction | Sebastian Huber | 2016-12-21 | 1 | -49/+13 | |
| | | | | Update #2852. | |||||
* | Add warnings to basic BSP chapters | Sebastian Huber | 2016-12-21 | 5 | -0/+20 | |
* | Move Shared Memory Support Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 | |
| | | | | | This chapter is very specific. Move it to a less prominent chapter position. | |||||
* | Move Ada95 Interrupt Support chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 | |
* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -1/+6 | |
| | | | | | | Move Timer Driver chapter. Update #2847. | |||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 3 | -2/+16 | |
| | | | | Close #2849. | |||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -218/+0 | |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | |||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -191/+0 | |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | |||||
* | Remove Analog Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -166/+0 | |
| | | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850. | |||||
* | Document I2C framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 | |
| | | | | Update #2845. | |||||
* | Document SPI framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 | |
| | | | | Update #2776. | |||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 11 | -21/+21 | |
* | Add script to update the version/revision | Sebastian Huber | 2016-12-21 | 1 | -0/+8 | |
* | Rework Clock Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -100/+137 | |
| | | | | Update #2737. | |||||
* | Document CPUINFO | Sebastian Huber | 2016-12-19 | 1 | -0/+70 | |
| | | | | Close #2723. | |||||
* | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 2016-12-19 | 1 | -32/+0 | |
| | | | | | | | Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | |||||
* | Do not mention obsolete Giant lock | Sebastian Huber | 2016-12-19 | 1 | -5/+0 | |
| | | | | Close #2555. | |||||
* | Update rtems_interrupt_frame description | Sebastian Huber | 2016-12-19 | 1 | -1/+2 | |
| | | | | Close #2808. | |||||
* | Document rtems_task_get_priority() | Sebastian Huber | 2016-12-19 | 1 | -0/+51 | |
| | | | | Close #2784. | |||||
* | Update Task Manager chapter | Sebastian Huber | 2016-12-13 | 1 | -184/+180 | |
| | | | | | | Introduce "Deprecated and Removed Directives" section. Update #2423. | |||||
* | Update Initialization Manager chapter | Sebastian Huber | 2016-12-12 | 3 | -100/+226 | |
| | | | | Update #2408. | |||||
* | Improve fatal error chapter | Sebastian Huber | 2016-12-12 | 3 | -64/+117 | |
| | | | | Update #2825. | |||||
* | Update linker set documentation | Sebastian Huber | 2016-12-06 | 1 | -2/+93 | |
| | | | | | Update #2408. Update #2790. | |||||
* | Improve fatal error chapter | Sebastian Huber | 2016-11-23 | 1 | -56/+120 | |
* | Rework fatal error chapter | Sebastian Huber | 2016-11-21 | 1 | -85/+267 | |
| | | | | Update #2811. | |||||
* | waf: Add networking to the manual built. | Chris Johns | 2016-11-15 | 1 | -7/+8 | |
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 2 | -33/+125 | |
* | cpu-supplement: Document PowerPC SPRG0-2 usage | Sebastian Huber | 2016-11-10 | 1 | -0/+11 | |
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 3 | -4/+13 | |
| | | | | build PDF. | |||||
* | filesystem: Fix header levels. | Chris Johns | 2016-11-09 | 12 | -2196/+1851 | |
* | cpu-supplement: Fix the project label. | Chris Johns | 2016-11-09 | 1 | -0/+2 | |
* | develenv: Fix header levels. | Chris Johns | 2016-11-09 | 7 | -10/+11 | |
* | eclipse: Fix heading levels. | Chris Johns | 2016-11-09 | 4 | -7/+37 | |
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 | |
* | cpu-supplement: Fix header levels. | Chris Johns | 2016-11-09 | 21 | -23/+24 | |
* | bsp-howto: Fix header levels. | Chris Johns | 2016-11-09 | 20 | -23/+22 | |
* | README: Add coding of spaces and no trailing white space. | Chris Johns | 2016-11-09 | 1 | -7/+9 | |
