* | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 2017-08-11 | 1 | -54/+23 |
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 2017-08-09 | 8 | -975/+1 |
| | | | | | | This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | ||||
* | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 2017-08-07 | 8 | -1/+975 |
* | bsp: Optional clock driver shutdown | Sebastian Huber | 2017-08-04 | 1 | -4/+8 |
* | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 2017-07-28 | 1 | -9/+140 |
| | | | | Close #2859. | ||||
* | posix1003-1, posix_users: mark mmap and shm functions implemented | Gedare Bloom | 2017-07-28 | 3 | -24/+23 |
| | | | | Update #2859. | ||||
* | README: fix typos | Gedare Bloom | 2017-07-26 | 1 | -8/+8 |
* | c-user: Fix interrupt lock documentation | Sebastian Huber | 2017-07-14 | 1 | -17/+35 |
| | | | | Update #3075. | ||||
* | c-user: Document new scheduler ident routines | Sebastian Huber | 2017-07-12 | 1 | -0/+83 |
| | | | | | Close #3069. Close #3070. | ||||
* | c-user: Update scheduler/task chapter | Sebastian Huber | 2017-07-10 | 2 | -34/+87 |
| | | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063. | ||||
* | c-user: Document EDF SMP | Sebastian Huber | 2017-06-30 | 2 | -0/+34 |
| | | | | Close #3056. | ||||
* | shell: Update task command | Sebastian Huber | 2017-06-16 | 1 | -3/+3 |
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 2 | -0/+447 |
| | | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | ||||
* | docs/rsb/configuration.rst: Fix typos, grammar. | Cillian O'Donnell | 2017-06-14 | 1 | -28/+28 |
* | cpu-supplement: Update TLS support status | Sebastian Huber | 2017-06-12 | 1 | -1/+1 |
| | | | | Close #2468. | ||||
* | bsp-howto: Warn about TERMIOS_TASK_DRIVEN | Sebastian Huber | 2017-06-08 | 1 | -0/+2 |
| | | | | Update #2935. | ||||
* | rsb: Mention Ada language option | Sebastian Huber | 2017-06-06 | 1 | -3/+6 |
* | User: Remove conflict marker. | Chris Johns | 2017-06-01 | 1 | -1/+0 |
* | User: Remove the stash conflict markers. | Chris Johns | 2017-05-31 | 1 | -4/+0 |
* | Fixes typos in README.txt | Tanu Hari Dixit | 2017-05-31 | 1 | -2/+2 |
| | | | | 2 typos fixed | ||||
* | User: Improvements to some of the tools commands. | Chris Johns | 2017-05-31 | 3 | -50/+51 |
* | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 2017-05-24 | 1 | -420/+282 |
* | c-user: Replace pre-emption with preemption | Sebastian Huber | 2017-05-11 | 2 | -8/+8 |
* | hosts.rst: Correct Ubuntu instructions | Linda Huxley | 2017-04-25 | 1 | -2/+2 |
| | | | | closes #3005. | ||||
* | README.txt: Add info after installing on CentOS 7 | Joel Sherrill | 2017-04-25 | 1 | -5/+22 |
* | c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulas | Joel Sherrill | 2017-04-25 | 1 | -9/+8 |
* | POSIX Users: Add posix_devctl() | Joel Sherrill | 2017-04-25 | 2 | -0/+76 |
* | Add Windows build details. | Chris Johns | 2017-03-27 | 2 | -1/+24 |
| | | | | Actually include the quoting fix for Windows. | ||||
* | waf: Fix linkcheck and spell commands. | Chris Johns | 2017-03-27 | 2 | -45/+27 |
| | | | | | | Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | ||||
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 14 | -42/+98 |
* | rsb: Fix the path to the tar for the untar with strip option. | Chris Johns | 2017-03-21 | 1 | -5/+6 |
| | | | | | | | The change is different to the ticket because the example is about coping and deploying the build on a different machine. Closes #2324. | ||||
* | user: Fix typo. | Chris Johns | 2017-03-21 | 1 | -1/+1 |
* | user: Minor fixes to rtems-bsp-builder. | Chris Johns | 2017-03-21 | 1 | -3/+3 |
* | user: Add an example of the rtems-bsp-builder running. | Chris Johns | 2017-03-21 | 1 | -2/+389 |
* | conf: Update the copyright year. | Chris Johns | 2017-03-21 | 1 | -2/+7 |
* | waf: Create the sphinx rule in one place. | Chris Johns | 2017-03-21 | 1 | -11/+11 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 17 | -76/+108 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 8 | -23/+621 |
* | waf: Configure check the inliner only once. | Chris Johns | 2017-03-15 | 1 | -5/+7 |
* | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 2017-03-08 | 1 | -1/+3 |
* | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 2017-03-07 | 1 | -31/+39 |
* | Add a check for Sphinx extensions. | Chris Johns | 2017-02-25 | 1 | -15/+44 |
| | | | | | | Minor clean up of the configure messages. Do not re-check sphinx in the nested configures. | ||||
* | Move extensions to common conf.py | Sebastian Huber | 2017-02-22 | 2 | -3/+2 |
* | Render math via JavaScript in HTML output | Sebastian Huber | 2017-02-20 | 2 | -4/+3 |
* | c-user: Fix linker set code blocks | Sebastian Huber | 2017-02-15 | 1 | -12/+13 |
* | c-user: Document linker set content | Sebastian Huber | 2017-02-15 | 1 | -0/+48 |
| | | | | Close #2770. | ||||
* | shell: Update task command | Sebastian Huber | 2017-02-14 | 1 | -3/+3 |
| | | | | Update #2858. | ||||
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 3 | -44/+40 |
| | | | | Update #2894. | ||||
* | c-user: Add SMP internal locking | Sebastian Huber | 2017-02-03 | 1 | -0/+38 |
