* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 14 | -0/+330 |
* | eng: Add function attributes | Sebastian Huber | 2020-11-09 | 1 | -0/+7 |
| | | | | Update #3715. | ||||
* | user: Add arm/stm32h7 | Sebastian Huber | 2020-10-27 | 3 | -0/+66 |
| | | | | Close #3910. | ||||
* | user: Rename files to match the chapter index | Sebastian Huber | 2020-10-27 | 2 | -0/+0 |
* | eng: Replace spec2doc.py with spec2modules.py | Sebastian Huber | 2020-10-24 | 1 | -7/+7 |
* | user/beagle: Add debug hardware mod | Chris Johns | 2020-10-19 | 2 | -0/+61 |
* | c-user: Generate I/O Manager documentation | Sebastian Huber | 2020-10-11 | 2 | -316/+481 |
| | | | | | | | | | The manager documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. This header file was generated from the items by a script. Update #3993. | ||||
* | eng: Add placement link role | Sebastian Huber | 2020-10-11 | 1 | -0/+12 |
* | eng: Move index-entries to all interfaces | Sebastian Huber | 2020-10-11 | 1 | -6/+5 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 15 | -60/+135 |
* | eng: Remove explicit figure class | Sebastian Huber | 2020-10-09 | 1 | -2/+0 |
| | | | | This makes the legend left justified. | ||||
* | images: Fix bld-deps.png size | Sebastian Huber | 2020-10-08 | 3 | -1/+1 |
* | eng: Add proper figure titles | Sebastian Huber | 2020-10-08 | 1 | -0/+4 |
| | | | | The first paragraph of a figure directive block is the figure title. | ||||
* | user: Fix RTEMS release URLs | Sebastian Huber | 2020-10-06 | 1 | -6/+6 |
* | Add AArch64 documentation | Kinsey Moore | 2020-10-05 | 3 | -1/+161 |
* | cpu-supplement: Fix formatting and missing words | Kinsey Moore | 2020-10-05 | 1 | -9/+9 |
* | eng: Clarify stlib build attribute | Sebastian Huber | 2020-10-01 | 1 | -13/+32 |
| | | | | Update #4107. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-09-28 | 1 | -1/+1 |
* | c-user: Fix use of getchark() and rtems_putc() | Sebastian Huber | 2020-09-28 | 1 | -4/+4 |
* | user: Add migration hints from old build system | Sebastian Huber | 2020-09-25 | 1 | -2/+96 |
| | | | | Update #3818. | ||||
* | i386: tweak grammar and style | Gedare Bloom | 2020-09-21 | 1 | -7/+4 |
* | pc386 BSP: add runtime options for debugging and move few lines around for ↵ | Karel Gardas | 2020-09-21 | 1 | -5/+27 |
| | | | | better context. | ||||
* | pc386 BSP: add a note about default baud rate for console over UART/COM. | Karel Gardas | 2020-09-21 | 1 | -0/+4 |
* | eng: Improve interrupt test image | Sebastian Huber | 2020-09-19 | 3 | -0/+0 |
* | eng/test-framework.rst -- Fix typo | Frank Kühndel | 2020-09-18 | 1 | -3/+3 |
* | eng: Remove double blank line | Sebastian Huber | 2020-09-18 | 1 | -1/+0 |
* | eng: Update release process | Sebastian Huber | 2020-09-18 | 1 | -2/+6 |
* | c-user: CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE | Sebastian Huber | 2020-09-17 | 1 | -0/+32 |
| | | | | | | Document this application configuration option. Update #3959. | ||||
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 1 | -0/+44 |
| | | | | | | Document this application configuration option. Close #4074. | ||||
* | Add missing <math.h> methods implemented as macros on compiler builtins. | Joel Sherrill | 2020-09-14 | 2 | -1357/+1357 |
| | | | | | | | These methods have long been provided and this change is needed on the 5.x branch and master. Closes #4075. | ||||
* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 7 | -154/+367 |
* | eng: Add BSP build system chapter | Sebastian Huber | 2020-09-13 | 14 | -0/+702 |
* | common: Enable numfig role | Sebastian Huber | 2020-09-13 | 1 | -0/+3 |
* | user/pc386 BSP: add documentation. | Karel Gardas | 2020-09-09 | 1 | -1/+395 |
| | | | | | The content is compiled from TBR pc386 wiki page, BSP's README files and from the actual BSP code. | ||||
* | user: Add xilinx-zynq BSP details | Chris Johns | 2020-09-08 | 1 | -2/+112 |
* | c-user: Split up scheduling concepts | Sebastian Huber | 2020-09-02 | 8 | -969/+995 |
| | | | | | | | | | Introduce a background section. This makes it easier to automatically generate parts of the scheduling concepts documentation in the future. Update #3993. | ||||
* | c-user: Split up user extensions manager | Sebastian Huber | 2020-09-02 | 5 | -162/+177 |
| | | | | | | | This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | ||||
* | c-user: Split up timer manager | Sebastian Huber | 2020-09-02 | 6 | -181/+200 |
* | c-user: Split up task manager | Sebastian Huber | 2020-09-02 | 6 | -626/+648 |
* | c-user: Split up signal manager | Sebastian Huber | 2020-09-02 | 7 | -323/+342 |
* | c-user: Split up region manager | Sebastian Huber | 2020-09-02 | 6 | -214/+233 |
* | c-user: Split up rate-monotonic manager | Sebastian Huber | 2020-09-02 | 7 | -1092/+1114 |
* | c-user: Split up partition manager | Sebastian Huber | 2020-09-02 | 6 | -121/+140 |
* | c-user: Split up message manager | Sebastian Huber | 2020-09-02 | 6 | -206/+225 |
* | c-user: Split up IO manager | Sebastian Huber | 2020-09-02 | 6 | -216/+235 |
* | c-user: Split up interrupt manager | Sebastian Huber | 2020-09-02 | 6 | -252/+271 |
* | c-user: Split up dual-ported memory manager | Sebastian Huber | 2020-09-02 | 6 | -85/+104 |
* | c-user: Split up clock manager | Sebastian Huber | 2020-09-02 | 6 | -223/+242 |
* | c-user: Split up barrier manager | Sebastian Huber | 2020-09-02 | 6 | -159/+174 |
* | c-user: Split up event manager | Sebastian Huber | 2020-09-02 | 7 | -310/+330 |
