* | Add script to update the version/revision | Sebastian Huber | 2016-12-21 | 1 | -0/+8 |
* | Rework Clock Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -100/+137 |
| | | | | Update #2737. | ||||
* | Document CPUINFO | Sebastian Huber | 2016-12-19 | 1 | -0/+70 |
| | | | | Close #2723. | ||||
* | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 2016-12-19 | 1 | -32/+0 |
| | | | | | | | Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | ||||
* | Do not mention obsolete Giant lock | Sebastian Huber | 2016-12-19 | 1 | -5/+0 |
| | | | | Close #2555. | ||||
* | Update rtems_interrupt_frame description | Sebastian Huber | 2016-12-19 | 1 | -1/+2 |
| | | | | Close #2808. | ||||
* | Document rtems_task_get_priority() | Sebastian Huber | 2016-12-19 | 1 | -0/+51 |
| | | | | Close #2784. | ||||
* | Update Task Manager chapter | Sebastian Huber | 2016-12-13 | 1 | -184/+180 |
| | | | | | | Introduce "Deprecated and Removed Directives" section. Update #2423. | ||||
* | Update Initialization Manager chapter | Sebastian Huber | 2016-12-12 | 3 | -100/+226 |
| | | | | Update #2408. | ||||
* | Improve fatal error chapter | Sebastian Huber | 2016-12-12 | 3 | -64/+117 |
| | | | | Update #2825. | ||||
* | Update linker set documentation | Sebastian Huber | 2016-12-06 | 1 | -2/+93 |
| | | | | | Update #2408. Update #2790. | ||||
* | Improve fatal error chapter | Sebastian Huber | 2016-11-23 | 1 | -56/+120 |
* | Rework fatal error chapter | Sebastian Huber | 2016-11-21 | 1 | -85/+267 |
| | | | | Update #2811. | ||||
* | waf: Add networking to the manual built. | Chris Johns | 2016-11-15 | 1 | -7/+8 |
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 2 | -33/+125 |
* | cpu-supplement: Document PowerPC SPRG0-2 usage | Sebastian Huber | 2016-11-10 | 1 | -0/+11 |
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 3 | -4/+13 |
| | | | | build PDF. | ||||
* | filesystem: Fix header levels. | Chris Johns | 2016-11-09 | 12 | -2196/+1851 |
* | cpu-supplement: Fix the project label. | Chris Johns | 2016-11-09 | 1 | -0/+2 |
* | develenv: Fix header levels. | Chris Johns | 2016-11-09 | 7 | -10/+11 |
* | eclipse: Fix heading levels. | Chris Johns | 2016-11-09 | 4 | -7/+37 |
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | cpu-supplement: Fix header levels. | Chris Johns | 2016-11-09 | 21 | -23/+24 |
* | bsp-howto: Fix header levels. | Chris Johns | 2016-11-09 | 20 | -23/+22 |
* | README: Add coding of spaces and no trailing white space. | Chris Johns | 2016-11-09 | 1 | -7/+9 |
* | README: Fix the header levels. | Chris Johns | 2016-11-09 | 1 | -6/+8 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 28 | -65/+88 |
* | shell: Fix header levels. | Chris Johns | 2016-11-09 | 9 | -15/+11 |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 38 | -57/+55 |
* | latex: Increase the depth of subsections. | Chris Johns | 2016-11-09 | 1 | -4/+7 |
* | README.txt: Add notes on Centos 6 and 7 | Joel Sherrill | 2016-11-08 | 1 | -5/+46 |
* | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 2016-11-08 | 2 | -4/+5 |
* | shell: Update commands to use descriptions. | Chris Johns | 2016-11-08 | 7 | -4488/+4303 |
* | waf: Get a copy of the optional packages. | Chris Johns | 2016-11-08 | 1 | -2/+2 |
* | waf: Use the good fonts if installed. | Chris Johns | 2016-11-08 | 5 | -22/+49 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 30 | -8135/+7796 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 3 | -2/+7 |
* | Add openSUSE installation hints | Sebastian Huber | 2016-11-07 | 1 | -1/+14 |
* | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 2016-11-07 | 4 | -146/+5 |
* | waf: Add a program test for pygmentize. | Chris Johns | 2016-11-07 | 1 | -0/+3 |
* | README: Add packages for building on Arch. | Christian Mauderer | 2016-11-07 | 1 | -0/+12 |
* | waf: Fix ''NoneType' object is not iterable' | Christian Mauderer | 2016-11-07 | 1 | -4/+6 |
* | README: Update with more host specific details. | Chris Johns | 2016-11-06 | 1 | -18/+40 |
* | waf: Fix the host version check. | Chris Johns | 2016-11-06 | 1 | -3/+3 |
* | waf: Add support to handle missing Latex packages on hosts they are not ↵ | Chris Johns | 2016-11-06 | 11 | -95/+1113 |
| | | | | | | | | | | available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font. | ||||
* | waf: note about tex noise when running configure. | Chris Johns | 2016-11-04 | 1 | -0/+3 |
* | README: Add host set up for CentOS for singlehtml. | Chris Johns | 2016-11-04 | 1 | -0/+5 |
* | waf: Check for texlive packages and report an error is not found. | Chris Johns | 2016-11-04 | 2 | -9/+198 |
* | waf: Fix the bnode issue when building in a manual directory. | Chris Johns | 2016-11-04 | 1 | -1/+1 |
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 7 | -109/+28 |
