* | spec: Move glossary specification | Sebastian Huber | 2020-10-26 | 4 | -108/+0 |
| | | | | | Move the glossary specification to the general specification to make it reusable. | ||||
* | Move glossary of terms to separate directory | Sebastian Huber | 2020-10-24 | 216 | -2874/+0 |
| | | | | This makes the glossary reusable in other specification domains. | ||||
* | spec: Add implemenation groups | Sebastian Huber | 2020-10-13 | 12 | -0/+168 |
* | spec: Improve wording | Sebastian Huber | 2020-10-13 | 1 | -1/+1 |
* | spec: Move Event Manager test cases | Sebastian Huber | 2020-10-13 | 2 | -1/+1 |
* | spec: Review Partition Manager | Sebastian Huber | 2020-10-13 | 3 | -10/+11 |
* | spec: Fix event send/receive validation | Sebastian Huber | 2020-10-12 | 1 | -2/+17 |
* | spec: Update rtems/basedefs/if/no-return | Sebastian Huber | 2020-10-12 | 1 | -0/+8 |
* | interface: Support function attributes | Sebastian Huber | 2020-10-12 | 6 | -13/+13 |
* | spec: Add function attributes | Sebastian Huber | 2020-10-12 | 203 | -0/+210 |
* | spec: Fix format | Sebastian Huber | 2020-10-12 | 6 | -59/+59 |
* | spec: Review Event Manager | Sebastian Huber | 2020-10-12 | 2 | -2/+3 |
* | spec: Rename documentation in placement order | Sebastian Huber | 2020-10-11 | 3 | -15/+17 |
* | spec: Rename event items | Sebastian Huber | 2020-10-09 | 13 | -4/+4 |
* | spec: Specify Partition Manager | Sebastian Huber | 2020-10-08 | 7 | -0/+1117 |
* | spec: Use RTEMS_TEST_VERBOSITY | Sebastian Huber | 2020-10-08 | 1 | -3/+3 |
* | spec: Review Partition Manager | Sebastian Huber | 2020-10-08 | 7 | -33/+240 |
* | spec: Review IO Manager | Sebastian Huber | 2020-10-08 | 9 | -15/+14 |
* | spec: Add index entries for IO Manager | Sebastian Huber | 2020-10-07 | 9 | -9/+19 |
* | spec: Move index-entries to interface type | Sebastian Huber | 2020-10-07 | 877 | -6/+880 |
* | spec: Set IO Manager documentation order | Sebastian Huber | 2020-10-07 | 1 | -0/+18 |
* | spec: Review Event Manager | Sebastian Huber | 2020-10-07 | 2 | -29/+35 |
* | spec: Add documentation order link role | Sebastian Huber | 2020-10-07 | 1 | -0/+22 |
* | spec: Fix format | Sebastian Huber | 2020-10-07 | 3 | -99/+99 |
* | spec: Canonicalize name and id checks | Sebastian Huber | 2020-10-07 | 2 | -14/+14 |
* | spec: Clarify stlib build attribute | Sebastian Huber | 2020-10-01 | 7 | -18/+49 |
* | spec: Fix IO Manager interface | Sebastian Huber | 2020-10-01 | 1 | -6/+6 |
* | spec: Fix IO Manager documentation | Sebastian Huber | 2020-09-30 | 6 | -7/+7 |
* | spec: Fix references in text attributes | Sebastian Huber | 2020-09-30 | 8 | -9/+11 |
* | spec: Review IO Manager | Sebastian Huber | 2020-09-29 | 17 | -128/+274 |
* | spec: Use rtems_message_queue_construct() | Sebastian Huber | 2020-09-28 | 1 | -6/+14 |
* | spec: Fix getchark | Sebastian Huber | 2020-09-28 | 1 | -1/+1 |
* | spec: Use a container for unspecified interfaces | Sebastian Huber | 2020-09-28 | 3 | -3/+3 |
* | spec: Place all interfaces in a header | Sebastian Huber | 2020-09-28 | 9 | -7/+56 |
* | spec: Add appl config opts to API domain | Sebastian Huber | 2020-09-28 | 14 | -0/+28 |
* | spec: Fix typo | Sebastian Huber | 2020-09-28 | 1 | -1/+1 |
* | spec: Review types | Sebastian Huber | 2020-09-25 | 7 | -9/+11 |
* | spec: Review options | Sebastian Huber | 2020-09-25 | 5 | -9/+13 |
* | spec: Review attributes | Sebastian Huber | 2020-09-25 | 19 | -38/+41 |
* | spec: Review task modes | Sebastian Huber | 2020-09-25 | 17 | -29/+34 |
* | spec: Review status codes | Sebastian Huber | 2020-09-25 | 21 | -33/+38 |
* | spec: Review configuration API | Sebastian Huber | 2020-09-25 | 21 | -44/+57 |
* | spec: Fix UID | Sebastian Huber | 2020-09-25 | 2 | -1/+1 |
* | spec: Add rtems_message_queue_construct() | Sebastian Huber | 2020-09-25 | 7 | -0/+702 |
* | spec: Use relative UID | Sebastian Huber | 2020-09-25 | 1 | -1/+1 |
* | spec: Fix function reference | Sebastian Huber | 2020-09-25 | 1 | -3/+3 |
* | spec: Move specification of specification items | Sebastian Huber | 2020-09-18 | 30 | -1007/+0 |
| | | | | This makes it reusable. | ||||
* | spec: Fix attribute validation test | Sebastian Huber | 2020-09-18 | 1 | -3/+3 |
* | spec: Delete resources in validation tests | Sebastian Huber | 2020-09-18 | 8 | -8/+31 |
* | spec: Add OAR copyright to <rtems.h> | Sebastian Huber | 2020-09-18 | 1 | -1/+2 |
| | | | | Clarify brief description. |
