* bit: zlib is now integrated into RTEMS cpukit and is at a much newer
version.
* RTEMS_Makefiles/Makefile.zlib, zlib-1.1.4/ChangeLog, zlib-1.1.4/FAQ,
zlib-1.1.4/INDEX, zlib-1.1.4/Make_vms.com, zlib-1.1.4/Makefile,
zlib-1.1.4/Makefile.in, zlib-1.1.4/Makefile.riscos,
zlib-1.1.4/README, zlib-1.1.4/adler32.c, zlib-1.1.4/algorithm.txt,
zlib-1.1.4/compress.c, zlib-1.1.4/configure, zlib-1.1.4/crc32.c,
zlib-1.1.4/deflate.c, zlib-1.1.4/deflate.h, zlib-1.1.4/descrip.mms,
zlib-1.1.4/example.c, zlib-1.1.4/gzio.c, zlib-1.1.4/infblock.c,
zlib-1.1.4/infblock.h, zlib-1.1.4/infcodes.c, zlib-1.1.4/infcodes.h,
zlib-1.1.4/inffast.c, zlib-1.1.4/inffast.h, zlib-1.1.4/inffixed.h,
zlib-1.1.4/inflate.c, zlib-1.1.4/inftrees.c, zlib-1.1.4/inftrees.h,
zlib-1.1.4/infutil.c, zlib-1.1.4/infutil.h, zlib-1.1.4/maketree.c,
zlib-1.1.4/minigzip.c, zlib-1.1.4/trees.c, zlib-1.1.4/trees.h,
zlib-1.1.4/uncompr.c, zlib-1.1.4/zconf.h, zlib-1.1.4/zlib.3,
zlib-1.1.4/zlib.h, zlib-1.1.4/zlib.html, zlib-1.1.4/zutil.c,
zlib-1.1.4/zutil.h, zlib-1.1.4/amiga/Makefile.pup,
zlib-1.1.4/amiga/Makefile.sas, zlib-1.1.4/contrib/README.contrib,
zlib-1.1.4/contrib/visual-basic.txt,
zlib-1.1.4/contrib/asm386/gvmat32.asm,
zlib-1.1.4/contrib/asm386/gvmat32c.c,
zlib-1.1.4/contrib/asm386/mkgvmt32.bat,
zlib-1.1.4/contrib/asm386/zlibvc.def,
zlib-1.1.4/contrib/asm386/zlibvc.dsp,
zlib-1.1.4/contrib/asm386/zlibvc.dsw,
zlib-1.1.4/contrib/asm586/README.586,
zlib-1.1.4/contrib/asm586/match.S,
zlib-1.1.4/contrib/asm686/README.686,
zlib-1.1.4/contrib/asm686/match.S,
zlib-1.1.4/contrib/delphi/zlib.mak,
zlib-1.1.4/contrib/delphi/zlibdef.pas,
zlib-1.1.4/contrib/delphi2/d_zlib.bpr,
zlib-1.1.4/contrib/delphi2/d_zlib.cpp,
zlib-1.1.4/contrib/delphi2/readme.txt,
zlib-1.1.4/contrib/delphi2/zlib.bpg,
zlib-1.1.4/contrib/delphi2/zlib.bpr,
zlib-1.1.4/contrib/delphi2/zlib.cpp,
zlib-1.1.4/contrib/delphi2/zlib.pas,
zlib-1.1.4/contrib/delphi2/zlib32.bpr,
zlib-1.1.4/contrib/delphi2/zlib32.cpp,
zlib-1.1.4/contrib/iostream/test.cpp,
zlib-1.1.4/contrib/iostream/zfstream.cpp,
zlib-1.1.4/contrib/iostream/zfstream.h,
zlib-1.1.4/contrib/iostream2/zstream.h,
zlib-1.1.4/contrib/iostream2/zstream_test.cpp,
zlib-1.1.4/contrib/minizip/ChangeLogUnzip,
zlib-1.1.4/contrib/minizip/Makefile,
zlib-1.1.4/contrib/minizip/miniunz.c,
zlib-1.1.4/contrib/minizip/minizip.c,
zlib-1.1.4/contrib/minizip/readme.txt,
zlib-1.1.4/contrib/minizip/unzip.c,
zlib-1.1.4/contrib/minizip/unzip.def,
zlib-1.1.4/contrib/minizip/unzip.h, zlib-1.1.4/contrib/minizip/zip.c,
zlib-1.1.4/contrib/minizip/zip.def, zlib-1.1.4/contrib/minizip/zip.h,
zlib-1.1.4/contrib/minizip/zlibvc.def,
zlib-1.1.4/contrib/minizip/zlibvc.dsp,
zlib-1.1.4/contrib/minizip/zlibvc.dsw,
zlib-1.1.4/contrib/untgz/Makefile,
zlib-1.1.4/contrib/untgz/makefile.w32,
zlib-1.1.4/contrib/untgz/untgz.c, zlib-1.1.4/msdos/Makefile.b32,
zlib-1.1.4/msdos/Makefile.bor, zlib-1.1.4/msdos/Makefile.dj2,
zlib-1.1.4/msdos/Makefile.emx, zlib-1.1.4/msdos/Makefile.msc,
zlib-1.1.4/msdos/Makefile.tc, zlib-1.1.4/msdos/Makefile.w32,
zlib-1.1.4/msdos/Makefile.wat, zlib-1.1.4/msdos/zlib.def,
zlib-1.1.4/msdos/zlib.rc, zlib-1.1.4/nt/Makefile.emx,
zlib-1.1.4/nt/Makefile.gcc, zlib-1.1.4/nt/Makefile.nt,
zlib-1.1.4/nt/zlib.dnt, zlib-1.1.4/os2/Makefile.os2,
zlib-1.1.4/os2/zlib.def: Removed.
