path: root/RTEMS_Makefiles/Makefile.readline-6.2 (follow)
* RTEMS_Makefiles/*: If the build works do a distcleanJoel Sherrill2015-05-271-0/+1
| | | | | The bit script did this by default if there wasn't a package specific Makefile.
* 2011-04-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-081-2/+0
| | | | | * RTEMS_Makefiles/Makefile.readline-6.2: Remove reference to old documentation.
* 2011-04-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-081-0/+18
* RTEMS_Makefiles/Makefile.readline-6.2, readline-6.2/CHANGELOG, readline-6.2/CHANGES, readline-6.2/COPYING, readline-6.2/INSTALL, readline-6.2/MANIFEST, readline-6.2/Makefile.in, readline-6.2/NEWS, readline-6.2/README, readline-6.2/USAGE, readline-6.2/aclocal.m4, readline-6.2/ansi_stdlib.h, readline-6.2/bind.c, readline-6.2/callback.c, readline-6.2/chardefs.h, readline-6.2/compat.c, readline-6.2/complete.c, readline-6.2/config.h.in, readline-6.2/configure, readline-6.2/configure.in, readline-6.2/display.c, readline-6.2/emacs_keymap.c, readline-6.2/funmap.c, readline-6.2/histexpand.c, readline-6.2/histfile.c, readline-6.2/histlib.h, readline-6.2/history.c, readline-6.2/history.h, readline-6.2/histsearch.c, readline-6.2/input.c, readline-6.2/isearch.c, readline-6.2/keymaps.c, readline-6.2/keymaps.h, readline-6.2/kill.c, readline-6.2/macro.c, readline-6.2/mbutil.c, readline-6.2/misc.c, readline-6.2/nls.c, readline-6.2/parens.c, readline-6.2/patchlevel, readline-6.2/posixdir.h, readline-6.2/posixjmp.h, readline-6.2/posixselect.h, readline-6.2/posixstat.h, readline-6.2/readline.c, readline-6.2/readline.h, readline-6.2/rlconf.h, readline-6.2/rldefs.h, readline-6.2/rlmbutil.h, readline-6.2/rlprivate.h, readline-6.2/rlshell.h, readline-6.2/rlstdc.h, readline-6.2/rltty.c, readline-6.2/rltty.h, readline-6.2/rltypedefs.h, readline-6.2/rlwinsize.h, readline-6.2/savestring.c, readline-6.2/search.c, readline-6.2/shell.c, readline-6.2/signals.c, readline-6.2/tcap.h, readline-6.2/terminal.c, readline-6.2/text.c, readline-6.2/tilde.c, readline-6.2/tilde.h, readline-6.2/undo.c, readline-6.2/util.c, readline-6.2/vi_keymap.c, readline-6.2/vi_mode.c, readline-6.2/xfree.c, readline-6.2/xmalloc.c, readline-6.2/xmalloc.h, readline-6.2/doc/Makefile.in, readline-6.2/doc/fdl.texi, readline-6.2/doc/history.0, readline-6.2/doc/history.3, readline-6.2/doc/history.dvi, readline-6.2/doc/history.html, readline-6.2/doc/history.info, readline-6.2/doc/history.pdf, readline-6.2/doc/history.ps, readline-6.2/doc/history.texi, readline-6.2/doc/history_3.ps, readline-6.2/doc/hstech.texi, readline-6.2/doc/hsuser.texi, readline-6.2/doc/readline.0, readline-6.2/doc/readline.3, readline-6.2/doc/readline.dvi, readline-6.2/doc/readline.html, readline-6.2/doc/readline.info, readline-6.2/doc/readline.pdf, readline-6.2/doc/readline.ps, readline-6.2/doc/readline_3.ps, readline-6.2/doc/rlman.texi, readline-6.2/doc/rltech.texi, readline-6.2/doc/rluser.texi, readline-6.2/doc/rluserman.dvi, readline-6.2/doc/rluserman.html, readline-6.2/doc/rluserman.info, readline-6.2/doc/rluserman.pdf, readline-6.2/doc/rluserman.ps, readline-6.2/doc/rluserman.texi, readline-6.2/doc/texi2dvi, readline-6.2/doc/texi2html, readline-6.2/doc/texinfo.tex, readline-6.2/doc/version.texi, readline-6.2/examples/Inputrc, readline-6.2/examples/Makefile.in, readline-6.2/examples/excallback.c, readline-6.2/examples/fileman.c, readline-6.2/examples/histexamp.c, readline-6.2/examples/manexamp.c, readline-6.2/examples/readlinebuf.h, readline-6.2/examples/rl-fgets.c, readline-6.2/examples/rl.c, readline-6.2/examples/rlcat.c, readline-6.2/examples/rlevent.c, readline-6.2/examples/rlptytest.c, readline-6.2/examples/rltest.c, readline-6.2/examples/rlversion.c, readline-6.2/examples/rlwrap-0.30.tar.gz, readline-6.2/examples/autoconf/BASH_CHECK_LIB_TERMCAP, readline-6.2/examples/autoconf/RL_LIB_READLINE_VERSION, readline-6.2/examples/autoconf/wi_LIB_READLINE, readline-6.2/examples/rlfe/ChangeLog, readline-6.2/examples/rlfe/Makefile.in, readline-6.2/examples/rlfe/README, readline-6.2/examples/rlfe/config.h.in, readline-6.2/examples/rlfe/configure, readline-6.2/examples/rlfe/configure.in, readline-6.2/examples/rlfe/extern.h, readline-6.2/examples/rlfe/os.h, readline-6.2/examples/rlfe/pty.c, readline-6.2/examples/rlfe/rlfe.c, readline-6.2/examples/rlfe/screen.h, readline-6.2/shlib/Makefile.in, readline-6.2/support/config.guess, readline-6.2/support/config.rpath, readline-6.2/support/config.sub, readline-6.2/support/install.sh, readline-6.2/support/mkdirs, readline-6.2/support/mkdist, readline-6.2/support/mkinstalldirs, readline-6.2/support/shlib-install, readline-6.2/support/shobj-conf, readline-6.2/support/wcwidth.c: New files.
