* | Eliminate configuring init mask modes since setting to default valueHEADmaster | Joel Sherrill | 2021-05-21 | 1 | -4/+0 |
* | Switch all tests to unlimited objects and unified workspace | Joel Sherrill | 2021-05-21 | 1 | -3/+4 |
* | Misc: Fix various warnings | Joel Sherrill | 2021-05-21 | 3 | -9/+9 |
* | Add various .gitignore files | Joel Sherrill | 2021-05-21 | 1 | -0/+1 |
* | Required changes to get back to a buildable state. | Jennifer Averett | 2021-05-21 | 2 | -2/+3 |
| | | | | | This primarily reflects changes since the legacy network stack was split into its own repository. | ||||
* | Remove ChangeLog files | Joel Sherrill | 2015-05-04 | 1 | -52/+0 |
* | Remove .cvsignore files | Joel Sherrill | 2015-05-04 | 1 | -2/+0 |
* | network-demos - Remove CVS Ids (scripted) | Joel Sherrill | 2012-05-15 | 6 | -18/+0 |
* | 2010-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-02-12 | 1 | -4/+4 |
| | | | | * ttcp/rtems_ttcp.c: Update timeval usage. | ||||
* | 2009-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-13 | 2 | -1/+5 |
| | | | | * Makefile: Allow overrides from invoking environment. | ||||
* | 2009-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-12 | 2 | -17/+22 |
| | | | | * init.c: Now build with libbsdport. | ||||
* | 2008-08-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-21 | 2 | -1/+6 |
| | | | | * ttcp_orig/ttcp.c: Fix warning. | ||||
* | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-25 | 2 | -0/+6 |
| | | | | * .cvsignore: New file. | ||||
* | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-25 | 3 | -2/+11 |
| | | | | | * Makefile: Build native ttcp as side-effect of main build. * rtems_ttcp.c: Fix warning. | ||||
* | 2007-08-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-08-16 | 4 | -3/+38 |
| | | | | | | * init.c: Change clock tick to 1 millisecond. * rtems_ttcp.c: Add CPU usage reporting. * ttcp_orig/ttcp.c: Add -m option for delaying between writes. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -0/+7 |
| | | | | * init.c: More warnings removed. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 3 | -30/+41 |
| | | | | | * rtems_ttcp.c, ttcp_orig/ttcp.c: Now compiles reasonably cleanly with CVS head. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -1/+5 |
| | | | | * init.c: confdefs.h should be rtems/confdefs.h | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -2/+6 |
| | | | | * init.c: Replace CONFIGURE_TEST_XXX with CONFIGURE_APPLICATION_XXX. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+7 |
| | | | | | * init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 1 | -0/+3 |
| | | | | * ChangeLog: New file. | ||||
* | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | 1999-12-14 | 1 | -1/+1 |
| | | | | value. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to take advantage of new | Joel Sherrill | 1999-04-01 | 1 | -13/+0 |
| | | | | routines in RTEMS. | ||||
* | Added debug print when test can't get a buffer. This is probably a fatal | Joel Sherrill | 1999-02-10 | 1 | -0/+1 |
| | | | | | error in the stack but it would be nice to get a message from the test just in case. | ||||
* | Modified to delay at startup. | Joel Sherrill | 1999-02-10 | 1 | -0/+3 |
* | Added CVS Id Strings which were missing | Joel Sherrill | 1998-08-21 | 6 | -0/+19 |
* | KA9Q -> FreeBSD changes from Eric Norum | Joel Sherrill | 1998-08-21 | 4 | -281/+46 |
* | Removed -- now provided by RTEMS | Joel Sherrill | 1998-08-21 | 5 | -0/+0 |
* | Added foreground task which can print KA9Q tables. | Joel Sherrill | 1998-08-12 | 2 | -33/+69 |
* | Added CVS Id. | Joel Sherrill | 1998-08-12 | 1 | -0/+4 |
* | Added undef of delay to avoid errors on some targets. | Joel Sherrill | 1998-08-12 | 1 | -0/+2 |
* | Added code to turn on debug. | Joel Sherrill | 1998-08-12 | 1 | -1/+12 |
* | Switched to using a single usercfg.h file. | Joel Sherrill | 1998-07-30 | 1 | -18/+2 |
* | base from Eric Norum -- Demos.30May1998.tar.gzDemos-30May1998ERIC-NORUM | Joel Sherrill | 1998-07-30 | 12 | -0/+1560 |
