* | Eliminate configuring init mask modes since setting to default valueHEADmaster | Joel Sherrill | 2021-05-21 | 1 | -4/+0 |
* | Switch all tests to unlimited objects and unified workspace | Joel Sherrill | 2021-05-21 | 1 | -5/+4 |
* | Misc: Fix various warnings | Joel Sherrill | 2021-05-21 | 1 | -1/+1 |
* | Required changes to get back to a buildable state. | Jennifer Averett | 2021-05-21 | 2 | -4/+4 |
| | | | | | This primarily reflects changes since the legacy network stack was split into its own repository. | ||||
* | Remove ChangeLog files | Joel Sherrill | 2015-05-04 | 1 | -32/+0 |
* | Remove .cvsignore files | Joel Sherrill | 2015-05-04 | 1 | -1/+0 |
* | network-demos - Remove CVS Ids (scripted) | Joel Sherrill | 2012-05-15 | 2 | -6/+0 |
* | 2009-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-13 | 2 | -1/+5 |
| | | | | * Makefile: Allow overrides from invoking environment. | ||||
* | 2009-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-12 | 2 | -24/+29 |
| | | | | * init.c: Now build with libbsdport. | ||||
* | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-25 | 2 | -0/+5 |
| | | | | * .cvsignore: New file. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -9/+15 |
| | | | | * init.c: More warnings removed. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -1/+5 |
| | | | | * init.c: confdefs.h should be rtems/confdefs.h | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -2/+6 |
| | | | | * init.c: Replace CONFIGURE_TEST_XXX with CONFIGURE_APPLICATION_XXX. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+7 |
| | | | | | * init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 1 | -0/+3 |
| | | | | * ChangeLog: New file. | ||||
* | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | 1999-12-14 | 1 | -1/+1 |
| | | | | value. | ||||
* | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 2 | -0/+143 |
