* | 2009-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-12 | 2 | -24/+29 |
| | | | | * init.c: Now build with libbsdport. | ||||
* | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-25 | 2 | -0/+5 |
| | | | | * .cvsignore: New file. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -9/+15 |
| | | | | * init.c: More warnings removed. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -1/+5 |
| | | | | * init.c: confdefs.h should be rtems/confdefs.h | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -2/+6 |
| | | | | * init.c: Replace CONFIGURE_TEST_XXX with CONFIGURE_APPLICATION_XXX. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+7 |
| | | | | | * init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | ||||
* | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-14 | 1 | -0/+3 |
| | | | | * ChangeLog: New file. | ||||
* | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | 1999-12-14 | 1 | -1/+1 |
| | | | | value. | ||||
* | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 2 | -0/+143 |
