summaryrefslogtreecommitdiff
path: root/cpukit/libtrace/record/record-dump-zbase64.c (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2020-03-18record: Add rtems_record_dump()Sebastian Huber
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib(). Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options. Update #3904.
