* ant5206.in, avrtest.in, bf537Stamp.in, csb337.in, csb350.in,
csb360.in, ezkit533.in, gdb-sim-run.in, gdbarmsim.in, gumstix.in,
h8sim.in, jmr3904.in, lm32_evr.in, m32csim.in, m32rsim.in, pc386.in,
psim.in, qemu-gumstix.in, qemu-leon2.in, qemuppc.in, rtl22xx.in,
simsh.in, sis.in, skyeye-support, smdk2410.in, tsim-support,
uC5282.in: Add running minimum to pick up path where there are no
Classic API Initialization Tasks. Minimum has IDLE task as first
application task.
* gdb-sim-run.in, gdb-sim.in, gumstix.in: Make graphics and network
interfaces potentially available on all simulator scripts. Add
configuration for network to gumstix.
csb360.in, ezkit533.in, gdb-sim-run.in, gumstix.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, psim.in, qemu-rtems.in,
rtl22xx.in, simsh.in, sis.in, skyeye-support, smdk2410.in,
tsim-support: echo rather than return time limit since the return
code is only 0-255 and we need limits longer than 255 seconds.
csb360.in, edb7312.in, ezkit533.in, gumstix.in, leon2-skyeye.in,
rtl22xx.in, skyeye-support, smdk2410.in: Move runARGS() and
gdbServerARGS() implementations to skyeye-support. They are the same
for all skyeye configurations.
* gumstix.in: Tinker with script to get more tests to run. Increase
time limits. Add LCD.
* gdb-sim-run.in: Skip pppd.exe
* gumstix.in: Skyeye isn't trusted yet.
* gdb-sim.in: Rearrange so check_status defined before used.
* gumstix.in: Fix typo.
* gumstix.in: Update to reflect latest support in Skyeye.
* gumstix.in: Attempt to fix coverage range for gumstix.
* Makefile: Add Gumstix on Skyeye script.
* gumstix.in: New file.
* rtl22xx.in: Add coverage enable to rtl22xx.
* .cvsignore, Makefile: Add rest of Skyeye configurations whether
they work completely at this point or not.
* ant5206.in, bf537Stamp.in, csb337.in, csb350.in, csb360.in,
ezkit533.in, rtl22xx.in, smdk2410.in: New files.
* Makefile, edb7312.in, gdb-sim-run.in, gdb-sim.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, psim.in, simsh.in, sis.in,
skyeye-support: Find run or gdb along PATH. Check for multiple RTEMS
versions so there is only one version of the script. Default the
simulator name so the BSP specific files do not have to do as much.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, mkrun, psim.in, simsh.in, sis.in:
Add ARM/edb7312 support. This is the first Skyeye BSP and adding this
required tinkering with all BSP scripts. All appear to still work OK.
* edb7312.in, skyeye-support: New files.
