2012-05-15 | network-demos - Remove CVS Ids (scripted) | Joel Sherrill | |
2009-05-13 | 2009-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Allow overrides from invoking environment. | |||
2009-05-12 | 2009-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Now build with libbsdport. | |||
2007-09-25 | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* .cvsignore: New file. | |||
2007-06-21 | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: More warnings removed. | |||
* init.c: confdefs.h should be rtems/confdefs.h | |||
* init.c: Replace CONFIGURE_TEST_XXX with CONFIGURE_APPLICATION_XXX. | |||
2003-01-28 | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | |||
2000-12-14 | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* ChangeLog: New file. | |||
1999-12-14 | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | |
value. | |||
1999-11-10 | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | |
