* networkconfig-qemu.h: VirtualBox uses 10.0.x.x for its eth0 so we
need to switch to 10.1.x.x for things to work smoothly.
* networkconfig-loopback.h: New file.
* networkconfig-qemu.h: Add missing endif.
* networkconfig.h, networkconfig-qemu.h, networkconfig-icecube.h,
networkconfig-mpc8313erdb.h: Loop back interface will be initialized
now during normal initialization via rtems_bsdnet_initialize_network().
* networkconfig-qemu.h: Now works on qemu with fxp driver in RTEMS, the
newer version in libbsdport, and on the real NIC in the Winsystems PC
in RTEMS Lab.
* networkconfig-qemu.h: Add option for qemu to use PCI i82551 NIC.
* networkconfig-qemu.h, networkconfig.h: Add missing initializers.
* networkconfig-icecube.h, networkconfig-qemu.h, networkconfig.h:
Updated to include new fields and expand tabs.
* networkconfig-qemu.h: Disable DHCP and use static IP.
* networkconfig.h: Use only loopback so tests can run OK on any target
even if they can't do anything.
* networkconfig-icecube.h: New file.
* networkconfig-qemu.h: New file.
