2009-09-17 | 2009-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.shared, networkconfig-qemu.h, cpuuse/Makefile, empty/Makefile, empty/empty.adb, exception_test2/Makefile, exception_test2/exceptiontest2.adb, exception_test3/Makefile, exception_test3/exceptiontest3.adb, hello_via_task/Makefile, hello_via_task/hello.adb, irq_test_c/Makefile: Make follow standard RTEMS test output format. Add output screens where appropriate. * exception_test2/exception_test2.scn, exception_test3/exception_test3.scn, hello_via_task/hello_via_task.scn: New files. | |||
* Makefile.shared, hello_via_task/.cvsignore: Update or add .cvsignore. * empty/.cvsignore, exception_test2/.cvsignore, exception_test3/.cvsignore: New files. | |||
2008-09-10 | 2008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Add new tests. Most of these eitehr demonstrate or verify a particular functionality. * cpuuse/Makefile, cpuuse/cpuuse.adb, exception_test2/Makefile, exception_test2/exceptiontest2.adb, exception_test3/Makefile, exception_test3/exceptiontest3.adb: New files. |
