2022-10-26 | Bumped version to 2.30 | Jiri Gaisler | |
2021-08-04 | Support extended interrupts2.29 | Sebastian Huber | |
2021-07-30 | Added GR740 L2 configuration register2.28 | Jiri Gaisler | |
2021-06-10 | Added simple RISC-V PLIC functionality for NS16550 interrupt | Jiri Gaisler | |
* RTEMS spconsole01 test now passes | |||
2020-12-15 | Added support for RISCV32 systems with CLINT/PLIC | Jiri Gaisler | |
2020-12-01 | Added emulation of GR740 SOC2.25 | Jiri Gaisler | |
* Only limited functionality with standard peripherals | |||
2020-10-28 | Add networking support using host tap device2.23 | Jiri Gaisler | |
* Emulation of GRETH 10/100 Mbit MAC and PHY * Supported only on linux | |||
2020-09-09 | Update to version 2.222.22 | Jiri Gaisler | |
2020-02-29 | Update to version 2.212.21 | Jiri Gaisler | |
2019-11-14 | Cross-platform support for async gdb break (ctrl-c) | Jiri Gaisler | |
2019-11-09 | Support building on MinGW-W64/MSYS22.19 | Jiri Gaisler | |
* Depends on MinGW64-readline to build | |||
2019-07-03 | Updated to version 2.172.17 | Jiri Gaisler | |
2019-07-02 | Make readline conditional and add linenoise it not present. | Chris Johns | |
- Readline is not present on all hosts is used on and it has not been a requirement. Rather than break all hosts that are working this patch conditionally adds linenoise a small simple realline replacement. | |||
2019-06-12 | Updated version to 2.162.16 | Jiri Gaisler | |
2019-05-31 | Fix build problems on Cygwin and FreeBSD | Jiri Gaisler | |
2019-05-28 | Made L1 cache optional through --enable-l1cache | Jiri Gaisler | |
* Removed stale config.h * Updated autoconf script with relevant checks * Re-implemented leon3/grlib timer with less events * Bumped version to 2.15 | |||
2019-05-21 | Completed texi manual | Jiri Gaisler | |
* Also removed unused constants in erc32.c | |||
2019-05-14 | Standalone sis - initial commit | Jiri Gaisler | |
