2022-10-26 | Add -extirq option to support simulating the UT700 | Sebastian Huber | |
2020-12-15 | Added support for RISCV32 systems with CLINT/PLIC | Jiri Gaisler | |
2020-12-01 | Added emulation of GR740 SOC2.25 | Jiri Gaisler | |
* Only limited functionality with standard peripherals | |||
2020-12-01 | Make grlib IP cores more modular and move them to grlib.c | Jiri Gaisler | |
2020-10-28 | Add networking support using host tap device2.23 | Jiri Gaisler | |
* Emulation of GRETH 10/100 Mbit MAC and PHY * Supported only on linux | |||
2020-10-25 | Add -rt option to synch sim to wall time | Jiri Gaisler | |
* Active during cpu power-down to avoid run-away sim time. Useful for interactive applications. | |||
2020-02-29 | Fix incorrect operation on big-endian hosts | Jiri Gaisler | |
2020-02-26 | Avoid reserved word sparc on SPARC hosts | Jiri Gaisler | |
2019-11-14 | Cross-platform support for async gdb break (ctrl-c) | Jiri Gaisler | |
2019-11-09 | Support building on MinGW-W64/MSYS22.19 | Jiri Gaisler | |
* Depends on MinGW64-readline to build | |||
2019-11-08 | Replaced windows flushing with reg cache | Jiri Gaisler | |
2019-11-08 | Improve gdb watchpoint handling | Jiri Gaisler | |
* show old/new values * stop at correct instruction | |||
2019-11-02 | Added support for gdb hw break/watchpoints | Jiri Gaisler | |
2019-07-02 | elf_load() failed in interactive shell. | Jiri Gaisler | |
2019-06-11 | Fix C formatting with indent | Jiri Gaisler | |
2019-06-11 | Silence warnings when compiled with LLVM | Jiri Gaisler | |
2019-05-28 | Made L1 cache optional through --enable-l1cache | Jiri Gaisler | |
* Removed stale config.h * Updated autoconf script with relevant checks * Re-implemented leon3/grlib timer with less events * Bumped version to 2.15 | |||
2019-05-27 | Add emulated L1 cache to SMP configurations | Jiri Gaisler | |
* Also improve timing accuracy for certain instructions | |||
2019-05-14 | Standalone sis - initial commit | Jiri Gaisler | |
