2020-06-30 | Change version to RTEMS 6 | Sebastian Huber | |
Update #4020. | |||
2017-11-13 | Change RTEMS_API from 5.0 to 5 | Sebastian Huber | |
This fixes the legacy Makefile based build system which expects RTEMS_API to be identical to the tool chain version. Update #3220. | |||
2017-11-09 | Upgrade to 5.0.0 | Sebastian Huber | |
Tool name will be "rtems5", e.g. arm-rtems5-gcc. Next release will 5.1.0. Branch version after release will be 5.1.1. Next master will be 6.0.0. | |||
2015-09-11 | Upgrade to 4.11.99.0 | Sebastian Huber | |
2011-03-04 | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | |||
2010-06-07 | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | |||
2008-09-22 | 2008-09-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* rtems/include/rtems/rtems/types.h: Do not define rtems_boolean, rtems_single, rtems_double unless RTEMS_DEPRECATED_TYPES is given. | |||
2007-09-21 | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | |||
2007-08-07 | Upgrade to 4.7.99.2 | Joel Sherrill | |
2007-03-13 | Upgrade to 4.7.99.1 | Joel Sherrill | |
2007-02-22 | Revert to version 4.7.99-0 | Ralf Corsepius | |
2007-02-22 | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | |
2006-10-18 | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | |||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/version.m4: Bump version to 4.7.99.0. | |||
2006-04-18 | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-4.6.99.3. | |||
2005-09-02 | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-4.6.99.2. | |||
2004-07-28 | 2004-07-28 | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-4.6.99.1. | |||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* aclocal/version.m4: 4.6.99.0. | |||
2003-12-17 | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-20031217-test. | |||
2003-07-03 | 2003-07-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-ss-20030703. | |||
2003-04-17 | 2003-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-ss-20030417. | |||
2003-04-11 | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-ss-20030411. | |||
* aclocal/version.m4: Updated to rtems-ss-20020411. | |||
2003-02-07 | missed in previous commit. | Joel Sherrill | |
2002-11-18 | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-ss-20021118. | |||
2002-11-11 | 2002-11-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-ss-20021111. | |||
2002-10-21 | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-20021021-test. | |||
2002-10-04 | 2002-10-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* aclocal/version.m4: Updated to rtems-JUNK. | |||
* aclocal/version.m4: Updated to rtems-ss-20021004. | |||
2002-08-08 | 2002-08-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add: Updated to binutils 2.13 which has no known issues. | |||
2002-06-17 | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* copied over from aclocal/. |
