Update #2948.
Update #2948.
This patch set adds a lot of new capability including support for
the leon2 and leon3. It also eliminates the difference between
the initial state of the simulated erc32 and the real hardware.
These patches are already present in the GCC 4.9 branch and will be
available with GCC 4.9.3.
This fixes the commit 4bdba3e552f22bbd82ffc9ab2c915a7b4f2eadd5 which
added a patch patch.
This patch updates and merges the previous SPARC patches as well
as providing update LEON2/LEON3 support in the SIS simulator.
This patch has issues related to the clock adjust interface but
it allows the package to build.
This patch is from the FreeBSD 10.0 devel/gdb port and adds the LDFLAGS to
link command line with Python enabled.
Note, this may effect some hosts if there are library clashes.
Fix the output from the simulator to gdb to use gdb interfaces
so the output is passes through the MI protocol if used.
Add a nouartrx option to the simulator so it does not block on
an stdin read. The termios settings put the tty into non-blocking
mode however the read sometimes blocks on high loads.
Change from the RTEMS thread model to the POSIX model. Do not enable
the weak support as it fails to link in the posix parts from the
RTEMS library. No weak support requires libstdc++'s makefile be
updated to handle RTEMS.
thread-local objects.
For *-*-elf it is already enabled by default. See comment line 810 in
"gcc/config.gcc".
Define TARGET_LIBGCC_SDATA_SECTION on PowerPC for RTEMS to ".sdata" to
place the __dso_handle. The __dso_handle is referenced by application
code. In case this code uses the small data section, the __dso_handle
must be there.
This patch should be committed to GCC 4.8 and 4.9.
Test results:
href="http://gcc.gnu.org/ml/gcc-testresults/2013-07/msg00671.html
http://sourceware.org/git/?p=binutils.git;a=commitdiff;h=cdef5ce2d07eefec59c3ef2157bc44a85df89157
http://sourceware.org/git/?p=binutils.git;a=commitdiff;h=9cd5917ee16c8d8b138bc7c6ffd76a97952b650d
http://sourceware.org/git/?p=binutils.git;a=commitdiff;h=fa75401a3f5c44e9f1ca1235135e579b833e26bb
This patch is included in the current GCC 4.7 branch.
http://sourceware.org/ml/newlib-cvs/2013-q1/msg00022.html
http://sourceware.org/cgi-bin/cvsweb.cgi/src/newlib/libc/machine/mips/memcpy.S.diff?r1=1.2&r2=1.3&cvsroot=src
http://sourceware.org/cgi-bin/cvsweb.cgi/src/newlib/libc/machine/mips/memcpy.S.diff?r1=1.1&r2=1.2&cvsroot=src
