2018-08-07 | rtemstoolkit: Various coverity related fixes. | Chris Johns | |
2014-10-30 | linkers: Add base image symbol to ELF object file generation. | Chris Johns | |
This change adds support to the rtems-syms code to generate a suitable ELF object you can link to the base image kernel in the embed mode or you can load with the run-time load mode. The change fixes a bug in the framework where local ELF symbols were being placed in the external symbol table. The external symbol table has been removed and a global, weak and local set of tables is now provided as this is more aligned with the ELF format. | |||
2014-09-13 | Refactor code into the RTEMS Toolkit. | Chris Johns | |
