- Add support to run the unit tests for the rtemstoolkit python
modules from waf. Enter './waf test' for the tests to be run on
python2 and python3.
- Update the importing of rtemstoolkit modules to the standard
method which works on python2 and python3.
- Update the README.
Moving the host support into a module lets it get used where options
is not being used.
Add solaris and netbsd.
Close #2619.
Support a top level VERSION file that defines an RTEMS release.
Fix the install of the python modules including thertems-test.
Update the git python module to the RSB version. Fix the options to
not call clean and to call dirty.
Update the version python module.
Fix the rtld C++ support to the VERSION file and the top level waf
script.
