2017-10-12 | rtemstoolkit: Fix error message in options. | Chris Johns | |
2017-04-25 | rtemstoolkit: Move host support access into a separate module. | Chris Johns | |
Moving the host support into a module lets it get used where options is not being used. | |||
2016-03-03 | Update rtems-tool to support Python 2 and 3. | Chris Johns | |
Add solaris and netbsd. Close #2619. | |||
2015-12-09 | Add release versioning support. | Chris Johns | |
Support a top level VERSION file that defines an RTEMS release. Fix the install of the python modules including thertems-test. Update the git python module to the RSB version. Fix the options to not call clean and to call dirty. Update the version python module. Fix the rtld C++ support to the VERSION file and the top level waf script. | |||
2015-11-12 | Python 3 compatibility | Sebastian Huber | |
2015-10-19 | Update the versions strings. | Chris Johns | |
2015-09-26 | rtems-tester.txt, options.py: Improved clarity and spelling. | Ric Claus | |
2014-02-15 | rt: Add the rtems-tester. | Chris Johns | |
