summaryrefslogtreecommitdiff
path: root/doc/rtems-tester.txt (follow)
AgeCommit message (Collapse)Author
2015-09-26rtems-test.txt: Some more clarity improvements.Ric Claus
2015-09-26rtems-tester.txt, options.py: Improved clarity and spelling.Ric Claus
2014-06-10rt: Update the documentation.Chris Johns
2014-05-12doc: rtems-tester.txt: Add information for building testsKumar Amit Mehta
The test executables will not be generated unless they are built explicitly by invoking 'make'.
2014-02-17Add the documentation.Chris Johns
